Home » Newcomers » Newcomers » eclipse crashes at startup
eclipse crashes at startup [message #900224] Sun, 05 August 2012 15:00 Go to next message
I recently installed eclipse 4.2 on my windows xp professional sp3.
whenever i try to run eclipse it crashes back to desktop on startup. It simply shows the eclipse logo for 1 second and then crashes, nothing else happens, no error message or anything.
please help me out.
my specifications are:
1.60 GHz, 504mb ram
i have an integrated intel video card of 128mb
[Updated on: Sun, 05 August 2012 15:02] by Moderator
Re: eclipse crashes at startup [message #900280 is a reply to message #900224] Mon, 06 August 2012 06:58 Go to previous messageGo to next message
How did you install it? You might also need more memory in your system than that.
Re: eclipse crashes at startup [message #900330 is a reply to message #900280] Mon, 06 August 2012 10:10 Go to previous messageGo to next message
I installed it from eclipse.org site.
are you sure that i need more memory to run eclipse. is there any other way possible through which i will be able to run it on my laptop.
Re: eclipse crashes at startup [message #900336 is a reply to message #900330] Mon, 06 August 2012 10:27 Go to previous messageGo to next message
That little memory might make things very tight.
Please copy and paste what's in your eclipse.ini file so we can see it.
Re: eclipse crashes at startup [message #900583 is a reply to message #900336] Tue, 07 August 2012 12:08 Go to previous messageGo to next message
-startup
plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.200.v20120522-1813
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256m
--launcher.defaultAction
openFile
-vmargs
-Xms40m
-Xmx512m
Re: eclipse crashes at startup [message #900584 is a reply to message #900336] Tue, 07 August 2012 12:08 Go to previous messageGo to next message
-startup
--launcher.library
-showsplash
256m
openFile
-vmargs
-Xms40m
-Xmx512m
Re: eclipse crashes at startup [message #900589 is a reply to message #900584] Tue, 07 August 2012 12:17 Go to previous message
On 8/7/2012 10:08 AM, kunal garg wrote:
> -startup
> --launcher.library
> -showsplash
> 256m
> openFile
> -vmargs
> -Xms40m
> -Xmx512m
Check out http://wiki.eclipse.org/Eclipse.ini. Also, as you've
downloaded 32-bit Eclipse, you must wire it up (see link) to a 32-bit JRE.
Previous Topic:Eclipse - extract data from XML file on a Server
Next Topic:Juno Update Site Problem (Win7, 64-bit)
Current Time: Sun Jul 20 04:40:08 EDT 2025
Powered by FUDForum. Page generated in 0.09626 seconds
