Home » Modeling » TMF (Xtext) » problem with string rule and double quote rule
problem with string rule and double quote rule [message #900500] Tue, 07 August 2012 06:10 Go to next message
I'm working on a DSL and i have a problem on the rule
It's just a part of my dsl:
Program:
'program' name=DoubleQuoteID
Value=STRING
'end'
DoubleQuoteID:
('"'ID'"')
terminal ID : ('a'..'z'|'A'..'Z') ('a'..'z'|'A'..'Z'|'0'..'9')*;
terminal STRING :
'"' ( '\\' ('b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\') | !('\\'|'"') )* '"' |
"'" ( '\\' ('b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\') | !('\\'|"'") )* "'"
terminal SL_COMMENT : (';') !('\n'|'\r')* ('\r'? '\n')?;
terminal WS : (' '|'\t'|'\r'|'\n')+;
I use to in parallel Xtend for realise junit test
My test :
class test{
@Inject extension ParseHelper<Program>
@Test def void testBadProgramDeclaration() {
val program =
program toto
"abc"
end
'''.parse
Assert::assertNotNull(program)
Assert::assertEquals("toto",program.name)//test pass but it shouldn't pass
Assert::assertEquals("abc",program.value)
@Test def void testGoodProgramDeclaration() {
val program =
program "toto"
"abc"
end
'''.parse
Assert::assertEquals("toto",program.name)// FAILED ==> expected:<toto> but was:<null>
I have a problem with the rule DoubleQuoteID because Double quote are obligatory but it's not define obligatory
I can't create a terminal for DoubledQuoteID because it create conflict with String rule
I don't know how i can do it
I'm new to Xtext and so this question might be quite stupid. Maybe somebody has an idea or can point me into the right direction? Thanks in advance!
Jérôme
Re: problem with string rule and double quote rule [message #900505 is a reply to message #900500] Tue, 07 August 2012 06:23 Go to previous messageGo to next message
Hi Jerome,
A DoubleQuoteID is a STRING, so the parser recognizes the more general rule.
I would define the name as a STRING and use a validation rule to check that the contents is a valid ID.
regards,
Vlad
Re: problem with string rule and double quote rule [message #900772 is a reply to message #900505] Wed, 08 August 2012 08:50 Go to previous message
thank you for your help
Previous Topic:How does the Serializer work? Reg. NFA + NodeModel
Next Topic:Rename/Move Resource refactoring for importURI-style includes
Current Time: Sun Jul 20 16:08:52 EDT 2025
Powered by FUDForum. Page generated in 0.06638 seconds
