Home » Archived » BIRT » Birt drill down chart(need information for showing target report on the same page)
Birt drill down chart [message #900040] Fri, 03 August 2012 11:19 Go to next message
I am facing an issue with the Birt Drill Down Report. I have a requirement to have three level of reports. On clicking on level1 report I need to show the level 2 report in the same page. Further clicking on the level 2 report I need to show the level 3 report below level 1 and level 2 report.
Approach1 :
Created three report design file for level 1, level 2 and level 3. Selected drill through hyperlink feature and set the target report location "Same Frame/ Parent Frame". But the drill down report is actually replacing the parent report(i.e. level 1 report).
Approach 2: Used birt tag library for calling the level 1 report. but still no luck.
Kindly can you please provide some input on this.
Saurav
Re: Birt drill down chart [message #900084 is a reply to message #900040] Fri, 03 August 2012 17:21 Go to previous messageGo to next message
Saurav,
Look at the attached example. It contains 3 jsp files. One that holds
two frames. The other two populate both frames. In the master report
(the one on top) I have a text element in the detail row of the first
column that contains a javascript function to update the bottom frame.
Jason
On 8/3/2012 11:19 AM, Saurav Kumar wrote:
> level 2 report.
> Approach1 :
> still no luck.
> Saurav
Re: Birt drill down chart [message #900086 is a reply to message #900040] Fri, 03 August 2012 17:21 Go to previous messageGo to next message
Saurav,
Jason
> level 2 report.
> Approach1 :
> still no luck.
> Saurav
Re: Birt drill down chart [message #900088 is a reply to message #900040] Fri, 03 August 2012 17:21 Go to previous messageGo to next message
Saurav,
Jason
> level 2 report.
> Approach1 :
> still no luck.
> Saurav
Re: Birt drill down chart [message #900089 is a reply to message #900040] Fri, 03 August 2012 17:21 Go to previous messageGo to next message
Saurav,
Jason
> level 2 report.
> Approach1 :
> still no luck.
> Saurav
Re: Birt drill down chart [message #900090 is a reply to message #900040] Fri, 03 August 2012 17:21 Go to previous messageGo to next message
Saurav,
Jason
> level 2 report.
> Approach1 :
> still no luck.
> Saurav
Re: Birt drill down chart [message #900091 is a reply to message #900040] Fri, 03 August 2012 17:21 Go to previous messageGo to next message
Saurav,
Jason
> level 2 report.
> Approach1 :
> still no luck.
> Saurav
Re: Birt drill down chart [message #900092 is a reply to message #900040] Fri, 03 August 2012 17:21 Go to previous messageGo to next message
Saurav,
Jason
> level 2 report.
> Approach1 :
> still no luck.
> Saurav
Re: Birt drill down chart [message #900214 is a reply to message #900084] Sun, 05 August 2012 12:55 Go to previous messageGo to next message
Hi Jason,
Thanks for your quick response. However I have a small query:
As in the example attached you have used frameset to display master and detail level report. Is there any other way to do the same. The reason why I am asking is that my application designed on JSF 1.2(which includes other components e.g. header body etc.) and I need to integrate the level 1 report inside that JSF page. However the frameset tags won't allow me to use the body tag of html/jsf page.
For the below approach :
I have two iframes that includes the two <birt:viewer> tags (one for level1 and one for level2) and while clicking on report 1 (pie chart slice or bar chart) is there any way to set the url for second <birt:viewer> tag(second level report) i.e. access the html components from inside of birt report.
Note:
I am getting out of memory error while running the 2-3 birt reports simultaneously. I have increased the app server JVM setting as you have mentioned in the forum but still no luck. Say from the future point of view if my application supports 50 odd users and all the users simultaneously access/generate the birt reports, will that create any problem for reports rendering such as "out of memory error".
Looking forward for your response.
Saurav
Re: Birt drill down chart [message #900393 is a reply to message #900214] Mon, 06 August 2012 16:34 Go to previous message
I assume you set MaxPermGen? Instead of using the tag libraries you can
specify the complete url for two iframes or frames. In the first report
you will have to do something similar to what I have in the example to
locate the second report and replace it when the user clicks on the
first. One thing you may want to do is do a clean install of the viewer
to tomcat and deploy the example I attached earlier and run it see how
it is done. If you want to call this from a chart you will need to use
the invokeScript as described here:
http://birtworld.blogspot.com/2009/12/calling-client-side-javascript-from.html
But instead of hiding and showing the table locate the the second frame
and reload the report in it.
Jason
On 8/5/2012 12:55 PM, Saurav Kumar wrote:
> Hi Jason,
> For the below approach : I have two iframes that includes the two
> Note:
> Saurav
Previous Topic:Does birt support nested axis label
Next Topic:Overflow not working in BIRT runtime engine
Current Time: Sun Jul 20 14:35:07 EDT 2025
Powered by FUDForum. Page generated in 0.25600 seconds
