Home » Eclipse Projects » GEF » Selectable but non dragable editpart
Selectable but non dragable editpart [message #900270] Mon, 06 August 2012 05:40 Go to next message
I want my editpart's children to be selectable(get the selection border on selection) but not dragable.
if i donot implement EditPolicy.LAYOUT_ROLE then editparts are not dragable but on selection border does not change
Any idea?
Re: Selectable but non dragable editpart [message #900303 is a reply to message #900270] Mon, 06 August 2012 08:25 Go to previous messageGo to next message
on your parent's layout policy:
protected EditPolicy createChildEditPolicy(EditPart child) {
    if (child instanceof ...) {
	return new NonResizableEditPolicy() {
	    public boolean isDragAllowed() {
		return false;
Re: Selectable but non dragable editpart [message #900310 is a reply to message #900303] Mon, 06 August 2012 08:58 Go to previous messageGo to next message
Thanks!
it worked fine. I have FlowLayoutEditPolicy as policy and i do not want children to move. Currently selected child can be draged with in parent to change the possition. Can i also disable this behavior?
Re: Selectable but non dragable editpart [message #900325 is a reply to message #900310] Mon, 06 August 2012 09:45 Go to previous message
Using the code I posted to you, it should works just like that.
Previous Topic:using GEF rich text in Graphiti application
Next Topic:Native DND drag over effect
Current Time: Sun Jul 20 16:00:38 EDT 2025
Powered by FUDForum. Page generated in 0.04151 seconds
