Home » Modeling » EMF » Why does EAnnoptation initialization code not set the annotation contents ?
Why does EAnnoptation initialization code not set the annotation contents ? [message #899859] Thu, 02 August 2012 12:03 Go to next message
I created an annotation with content objects.
My attached Model mypackage.ecore contains 2 instances of class State
inside the "States" annotation for MyRootObject eClass,
but I don't see any attempts in the templates to reflect this in the
generated
MypackagePackageImpl.java which contains the default generated code:
* Initializes the annotations for <b>States</b>.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
protected void createStatesAnnotations() {
String source = "States";
addAnnotation(myRootObjectEClass, source, new String[] {});
the latter call addAnnotation(myRootObjectEClass, source, new
String[] {});
does NOT even try to set the annotation contents.
Why?
Regards, Philipp
Re: Why does EAnnoptation initialization code not set the annotation contents ? [message #899894 is a reply to message #899859] Thu, 02 August 2012 13:28 Go to previous message
Philipp,
Comments below.
> generated
No. Even to try, we'd need the GenModel for the eClass() of the
instance objects...
> * @generated
> String[] {});
> Why?
It's not a trivial problem. You could try setting the GenPackage to use
Initialize by Loading; the contain objects should be serialized and if
the generated model is available during loading, they should be resurrected.
> Regards, Philipp
Previous Topic:Find ItemPropertyDescriptors by EClass instead of concrete instance
Next Topic:[CDO] Deprecated config elements in cdo-server.xml ?
Current Time: Sat Jul 19 20:07:08 EDT 2025
Powered by FUDForum. Page generated in 0.02521 seconds
