Home » Eclipse Projects » Virgo » How to configure Embeded tomcat settings programatically in Virgo(How to configure Embeded tomcat settings programatically in Virgo)
How to configure Embeded tomcat settings programatically in Virgo [message #899204] Tue, 31 July 2012 00:46 Go to next message
Hi I am using Virgo Tomcat Server virgo-tomcat-server-3.5.0.M04.
I want to change some of the tomcat settings of the embedded tomcat in Virgo like Port host etc dynamically.
What is the option to do that.
I tried to serach on different forums.
I tried to create a fragment having fragment-host as com.springsource.org.apache.catalina and provided the tomcat-server.xml with the new settings but VTS does not pick up these settings.
Please let me know how can it be achieved.
Re: How to configure Embeded tomcat settings programatically in Virgo [message #899313 is a reply to message #899204] Tue, 31 July 2012 09:03 Go to previous messageGo to next message
Check the user guide: http://www.eclipse.org/virgo/documentation/virgo-documentation-3.5.0.RELEASE/docs/virgo-user-guide/htmlsingle/virgo-user-guide.html#configuring-tomcat
tomcat-server.xml is located in $SERVER_HOME/configuration
Violeta
Re: How to configure Embeded tomcat settings programatically in Virgo [message #899468 is a reply to message #899313] Wed, 01 August 2012 00:27 Go to previous messageGo to next message
Thanks!!
I have gone through this.
What I wanted is how can I configure it programatically where in Virgo Tomcat server will pickup my tomcat-server.xml and not the OOTB tomcat-server.xml provided by Virgo.
I should be able to configure the tomcat settings like port host etc dynamically, without manually changing the configurations from tomcat-server.xml of OOTB Virgo.
Re: How to configure Embeded tomcat settings programatically in Virgo [message #899596 is a reply to message #899468] Wed, 01 August 2012 10:28 Go to previous messageGo to next message
You can change Apache Tomcat settings runtime through MBeans (is that you want?).
For example there is MBean for Connector etc.
One point here is that these settings will not be persisted.
[Updated on: Wed, 01 August 2012 10:29] by Moderator
Re: How to configure Embeded tomcat settings programatically in Virgo [message #899621 is a reply to message #899596] Wed, 01 August 2012 11:22 Go to previous message
My requirement is to change the tomcat port, SSL settings etc dynamically. How can I use MBeans for that? Can you please explain it to me.
Secondly why these settings will not persisted? Can you please explain about it.
Tried to add a fragment as a fragment-host for bundle org.eclipse.gemini.web.tomcat. This fragment is containing the modified tomcat-server.xml file.
I tried to add it as part of the plan org.eclipse.virgo.web.tomcat_3.5.0.M04.plan as follows:
<artifact type="configuration" name="org.eclipse.virgo.web"/>
<artifact type="bundle" name="org.eclipse.gemini.web.core" version="[2.0, 3.0)"/>
<artifact type="bundle" name="org.eclipse.gemini.web.tomcat" version="[2.0, 3.0)"/>
<artifact type="fragment" name="tomcatcustom" version="1.0"/>
<artifact type="bundle" name="org.eclipse.virgo.web.core" version="[3.0, 4.0)"/>
<artifact type="bundle" name="org.eclipse.virgo.web.dm" version="[3.0, 4.0)"/>
<artifact type="bundle" name="org.eclipse.virgo.web.tomcat.support" version="[3.0, 4.0)"/>
As this plan is part of org.eclipse.virgo.kernel.userregion.properties as part of the initialArtifacts as follows:
initialArtifacts=repository:plan/org.eclipse.virgo.kernel.userregion.springdm, repository:plan/org.eclipse.virgo.web.tomcat
When I start Virgo server I am getting following error.
[2012-08-01 14:46:52.681] start-signalling-1 <DE0005I> Started plan 'org.eclipse.virgo.kernel.userregion.springdm' version '3.0.0'.
[2012-08-01 14:46:52.978] system-artifacts <DE0000I> Installing plan 'org.eclipse.virgo.web.tomcat' version '3.0.0'.
[2012-08-01 14:46:53.024] system-artifacts <DE0000I> Installing configuration 'org.eclipse.virgo.web' version '0.0.0'.
[2012-08-01 14:46:53.478] system-artifacts <DE0000I> Installing bundle 'org.eclipse.gemini.web.core' version '2.1.0.M03'.
[2012-08-01 14:46:54.071] system-artifacts <DE0000I> Installing bundle 'org.eclipse.gemini.web.tomcat' version '2.1.0.M03'.
[2012-08-01 14:46:54.071] system-artifacts <DE0700E> Cannot find fragment 'tomcatcustom' version range '[1.0.0, oo)' in repository 'ext-usr'.
[2012-08-01 14:46:54.149] system-artifacts <DE0002E> Installation of plan 'org.eclipse.virgo.web.tomcat' version '3.0.0' failed. org.eclipse.virgo.kernel.deployer.core.DeploymentException: Deployment of plan 'org.eclipse.virgo.web.tomcat' version '3.0.0' in scope 'null'
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.operate(PlanResolver.java:116)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.access$0(PlanResolver.java:92)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver$1.visit(PlanResolver.java:86)
at org.eclipse.virgo.util.common.ThreadSafeGraphNode.visitInternal(ThreadSafeGraphNode.java:193)
at org.eclipse.virgo.util.common.ThreadSafeGraphNode.visit(ThreadSafeGraphNode.java:184)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.transform(PlanResolver.java:82)
at org.eclipse.virgo.kernel.install.pipeline.stage.transform.internal.TransformationStage.doProcessGraph(TransformationStage.java:54)
at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipelineStage.process(AbstractPipelineStage.java:41)
at org.eclipse.virgo.kernel.install.pipeline.internal.StandardPipeline.doProcessGraph(StandardPipeline.java:62)
at org.eclipse.virgo.kernel.install.pipeline.internal.CompensatingPipeline.doProcessGraph(CompensatingPipeline.java:73)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDeployer.java:360)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.doInstall(PipelinedApplicationDeployer.java:184)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.install(PipelinedApplicationDeployer.java:139)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:252)
at org.eclipse.virgo.kernel.userregion.internal.InitialArtifactDeployer$ArtifactDeployingRunnable.deployArtifacts(InitialArtifactDeployer.java:156)
at org.eclipse.virgo.kernel.userregion.internal.InitialArtifactDeployer$ArtifactDeployingRunnable.run(InitialArtifactDeployer.java:146)
at java.lang.Thread.run(Thread.java:619)
Caused by: org.eclipse.virgo.kernel.deployer.core.DeploymentException: fragment 'tomcatcustom' in version range '[1.0.0, oo)' not found
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.obtainInstallArtifactGraph(PlanResolver.java:165)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.operate(PlanResolver.java:101)
... 19 common frames omitted
[2012-08-01 14:46:54.196] system-artifacts <DE0003E> Install failed for configuration 'org.eclipse.virgo.web' version '0.0.0'.
[2012-08-01 14:46:54.196] system-artifacts <DE0003E> Install failed for bundle 'org.eclipse.gemini.web.core' version '2.1.0.M03'.
[2012-08-01 14:46:54.212] system-artifacts <DE0003E> Install failed for bundle 'org.eclipse.gemini.web.tomcat' version '2.1.0.M03'.
[2012-08-01 14:46:54.337] system-artifacts <DE0003E> Install failed for plan 'org.eclipse.virgo.web.tomcat' version '3.0.0'.
[2012-08-01 14:46:54.353] system-artifacts <UR0002E> User region failed while deploying initial artifacts. Shutting down.
[2012-08-01 14:46:54.462] System Bundle Shutdown <KE0010I> Shutdown initiated.
Please let me know. Thanks in advance!!
Previous Topic:Virgo and Mobicents, Integration issues
Next Topic:Missing artifact org.eclipse.virgo.mirrored:org.eclipse.osgi:jar:3.8.0.v20120508-2119
Current Time: Sat Jul 19 18:51:10 EDT 2025
Powered by FUDForum. Page generated in 0.25189 seconds
