EcoreUtil.Copier does not keep order of lists [message #899549] |
Wed, 01 August 2012 07:50  |
I have an ecore model consisting of a diagram (container), objects and relations.
The objects have a reference attribute to a relation and the relation has a list of objects that are part of the relation.
Note that both the objects and the relations are contained by the diagram (in a list).
Lets say I want to copy two objects and a relation (containing references to these objects in its list), using EcoreUtil.Copier.
This results in the copies, where the objects refer to the new relation and the new relation contains a list of the newly copied objects.
The only problem is that the order of the list of objects of the copied reference is not defined.
Sometimes it is correct and sometimes it is wrong. (I suppose it depends on the order of objects in the HashMap of the Copier).
Is this expected behavior of Copier, or is it a bug and should I report it?
Note: I have added code to properly order copied lists to match the original order (for lists that have the ordered ecore attribute set) to prevent this problem/bug.
Maarten
Re: EcoreUtil.Copier does not keep order of lists [message #899554 is a reply to message #899549] |
Wed, 01 August 2012 08:02   |
Maarten,
Comments below.
On 01/08/2012 1:50 PM, Maarten Bezemer wrote:
> Hello,
> relations.
> objects.
I don't really see how that's possible. Copier.copyReference walks the
list is adds the copies as it proceeds; order doesn't depend on the
copier's map, which is just used keep track of the mapping from
originals to copies..
> report it?
No. If you have a reproducible test case, definitely file a bugzilla.
It's hard to imagine that something that's been so long in use would
have such a glaring problem...
> Regards,
> Maarten
Re: EcoreUtil.Copier does not keep order of lists [message #899672 is a reply to message #899556] |
Wed, 01 August 2012 14:25   |
Marteen,
Comments below.
On 01/08/2012 2:14 PM, Maarten Bezemer wrote:
>> > The only problem is that the order of the list of objects of the >
>> > Sometimes it is correct and sometimes it is wrong. (I suppose it >
>> the list is adds the copies as it proceeds; order doesn't depend on
>> the copier's map, which is just used keep track of the mapping from
> Problem is it does not walk the list.
Yes it does, in copyReferences.
> It walks only containing lists (which is the one in the diagram).
It walks the containment tree first so that it can establish which
objects are copied and their correspondence...
> The two objects get added to the reference list, because it walks the
> objects attributes.
All the object's features.
> Hence my thought that the order depends on the order of the Copier
> HashMap.
> From EcoreUtil.Copier:
> public void copyReferences()
> for (Map.Entry<EObject, EObject> entry : entrySet())
That just walks the pairs of orginals and their copies so that it can
transfer the feature values from original to the copy; the order in
which this is done is irrelevant in terms of how the values of a
multivalued feature is walked.
>> > Is this expected behavior of Copier, or is it a bug and should I >
>> report it?
> It is part of a much bigger application, so before I spend time in
> creating a test case, I though I ask here first... :)
Is there something special about the model's implementation of the
feature for which the order isn't being preserved? That seems more
likely to be the cause. You could set a breakpoint in copyReference for
when that feature is copied; but I guess you did that and in those cases
it works properly...
>> set) > to prevent this problem/bug.
> Exactly my thoughts...
FUDForum. Page generated in 0.04174 seconds
