Home » Modeling » TMF (Xtext) » weird encoding problem with properties-files(wrong encoding when generating properties-file the first time)
weird encoding problem with properties-files [message #899325] Tue, 31 July 2012 09:28 Go to next message
Hi!
I am working on a DSL that generates properties files in order to deal with translations. I came across a weird encoding problem:
The encoding for properties files must be ISO-8859-1. Eclipse sets the encoding automatically correct as soon as the properties file is created. But when the generator is called for the first time, the properties file is corrupted, although the encoding is correct.
You might want to try the following example:
grammar:
Model:
	keyAndValues+=KeyAndValue*;
KeyAndValue:
	name = ID value = STRING;
generator:
class MyDslGenerator implements IGenerator {
	override void doGenerate(Resource resource, IFileSystemAccess fsa) {
		if (resource.contents.size > 0) {
			val model = resource.contents.get(0) as Model;
			fsa.generateFile("test.properties", generatePropertyFile(model));
	def generatePropertyFile(Model it) '''
		«FOR KeyAndValue keyAndValue : keyAndValues»
			«keyAndValue(keyAndValue)»
		«ENDFOR»
	def keyAndValue(KeyAndValue it) '''«name» = «value»'''
test.mydsl:
testKey1 = äöü
results in test.properties:
testKey1 = aöü
If you call fsa.generateFile twice, everything is fine.
I debugged into EclipseResourceFileSystemAccess2 and saw that there is a distinction if the file already exists or not. Maybe eclipse sets the encoding to ISO-8859-1 after the file was generated and the content written to it and corrupts it by doing so?
Re: weird encoding problem with properties-files [message #899415 is a reply to message #899325] Tue, 31 July 2012 14:10 Go to previous messageGo to next message
Hi Annette,
we use IFile.getCharset to determine the encoding. You want to bind a
custom IFileSystemAccess that returns ISO-8859-1 if the file extension
is *.properties?
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 31.07.12 15:28, schrieb Annette Pohl:
> Hi!
> grammar:
> Model:
> KeyAndValue:
> generator:
> «ENDFOR»
> test.mydsl:
> testKey1 = äöü
> testKey1 = aöü
Re: weird encoding problem with properties-files [message #899526 is a reply to message #899415] Wed, 01 August 2012 05:48 Go to previous message
Hi Sebastian,
thanks for your answer. This is working now:
public class MyDslFileSystemAccess extends EclipseResourceFileSystemAccess2 {
	private static final Logger LOGGER = LoggerFactory.getLogger( MyDslFileSystemAccess.class );
	protected IFile getFile( String fileName, String outputName ) {
		IFile file = super.getFile( fileName, outputName );
		if (fileName != null && fileName.endsWith( "properties" ) && !file.exists()) {
			try {
				file.create(getInputStream("", file.getCharset(true)), true, getMonitor());
			} catch (CoreException e) {
				LOGGER.error( "failed to create file {} : {}", fileName, e.getMessage() );
		return file;
I tried first to set the charset for file, but I got an exception when I called the generator the first time and the properties file did not exist yet. The exception complained that the resource did not exist. When I called the generator the second time everything was working and the charset could be set - but this was working anyway. My problem was the first call of the code generator.
So I created the file before setting the charset and now it was working. Then I tried if it was necessary to set the charset and found out that it was not. Creating the file was enough.
Thanks for your help - it pointed me to the right direction.
Previous Topic:scoping problem
Next Topic:[Grammar] Declaration and definition of variables for a DSL
Current Time: Sun Jul 20 07:56:50 EDT 2025
Powered by FUDForum. Page generated in 0.04566 seconds
