Home » Modeling » EMF » How to impact the notification refresh value(EMF edit item provider does not have content refresh for all refrences)
How to impact the notification refresh value [message #899377] Tue, 31 July 2012 11:42 Go to next message
I have a large model and many of the classes are referenced as containment or association.
When I generate the EDIT code not all references appear in the notification.
Because of that the tree in the editor does not refresh when a reference to association is changed. Only contained references are refresh.
For example: one of the classes generated the following which is only the contained refernces
public void notifyChanged(Notification notification) {
updateChildren(notification);
switch (notification.getFeatureID(InterfaceEntity.class)) {
case FSDModelPackage.INTERFACE_ENTITY__INTERFACE_TYPE:
case FSDModelPackage.INTERFACE_ENTITY__RELATED_MAPPPER_NAMES:
fireNotifyChanged(new ViewerNotification(notification, notification.getNotifier(), false, true));
return;
case FSDModelPackage.INTERFACE_ENTITY__INTERFACE_MESSAGE_MAPPER:
case FSDModelPackage.INTERFACE_ENTITY__INTERFACE_SERVICE_CALLS:
fireNotifyChanged(new ViewerNotification(notification, notification.getNotifier(), true, false));
return;
super.notifyChanged(notification);
I would expect it to generate all the references like this:
return;
case FSDModelPackage.INTERFACE_ENTITY__ICD:
case FSDModelPackage.INTERFACE_ENTITY__INTERFACE_MESSAGE:
case FSDModelPackage.INTERFACE_ENTITY__OPERATION:
return;
How can I control this list to make sure ALL references are in it?
I know I can change the notify property in the genmodel but that will add the reference to the label update and not the viewer update list.
I want to have the viewer content change.
[Updated on: Tue, 31 July 2012 11:58] by Moderator
Re: How to impact the notification refresh value [message #899431 is a reply to message #899377] Tue, 31 July 2012 15:01 Go to previous messageGo to next message
Yigal,
Comments below.
> notification.
That depends on what you've set for the properties of the corresponding
GenFeatures...
> refresh.
> return;
> case
> case
> return;
> @Override
> return;
> case
> case
> return;
Set the Notify property of each GenFeature to true.
Re: How to impact the notification refresh value [message #899440 is a reply to message #899431] Tue, 31 July 2012 15:55 Go to previous messageGo to next message
Since my model is huge and there is a lot of manual work, I'll like to make it programmatic.
I know how to open the genmodel as a resource and get to the genPackage.
How do I get from the gen package to notify element in the edit section?
I tested you Notify change and it works great.
Yigal
Re: How to impact the notification refresh value [message #899442 is a reply to message #899440] Tue, 31 July 2012 16:23 Go to previous message
Yigal,
Comments below.
GenPackages contains GenClassifiers, some of which are GenClasses that
contain GenFeatures. This containment structure should be apparent
looking at the tree view in the Generator.
> Thanks
> Yigal
Previous Topic:[CDO] Productive Use and Schema Evolution
Next Topic:[CDO] Edapt and CDO model migration
Current Time: Sat Jul 19 16:39:08 EDT 2025
Powered by FUDForum. Page generated in 0.03570 seconds
