How is installFeature action supposed to work? [message #899135] |
Mon, 30 July 2012 11:53  |
Hi all,
We are currently facing the problem of turning an implicitly installed
feature (from a feature dependency) into a root feature via an update to
the RCP application. I though that could be accomplished with the
installFeature touchpoint action, but this does not work, because the
feature to be installed by this action must be among the artifacts of
the current feature. This is obviously not the case, I have never seen
an feature.group being the artifact of another feature (is this even
possible?). This is a bit disappointing since this seemed to be the only
way of accomplishing the task. Two question:
1. Why is installFeature restricted to artifacts of the current IU
(which in almost all cases does not make sense I believe)?
2. Is there another way of turning a non-root IU into a root IU without
explicitly installing the IU?
The overall goal is to make the non-root IU uninstallable, which isn't
possible if it isn't a root IU (only).
Thorsten
Re: How is installFeature action supposed to work? [message #899357 is a reply to message #899306] |
Tue, 31 July 2012 10:24   |
Hi Hendrik,
Could you point me to or send me more details on how you did this?
Thorsten
Am 31.07.2012 14:30, schrieb Henrik Lindberg:
> We had the same/similar issue in cloudsmith / geppetto @ github. Our
> solution was to ship a "run once" bundle that used the p2 API to make
> the modifications.
> Regards
> - henrik
> On 2012-30-07 17:53, Thorsten Meinl wrote:
>> Hi all,
>> Cheers,
>> Thorsten
Re: How is installFeature action supposed to work? [message #899586 is a reply to message #899357] |
Wed, 01 August 2012 10:08  |
On 2012-31-07 16:24, Thorsten Meinl wrote:
> Hi Hendrik,
The code for the "run once" is here:
https://github.com/cloudsmith/geppetto/blob/master/org.cloudsmith.geppetto.onetimeinstall/src/org/cloudsmith/geppetto/onetimeinstall/Activator.java
Hope that helps you.
- henrik
> Thorsten
>> the modifications.
>> Regards
>> - henrik
>>> Hi all,
>>> Cheers,
>>> Thorsten
FUDForum. Page generated in 0.05351 seconds
