Home » Language IDEs » ServerTools (WTP) » Associate Custom Content Type with XML Validator.
Associate Custom Content Type with XML Validator. [message #898993] Mon, 30 July 2012 00:47 Go to next message
Just want to know what should come in place of question marks ?? in the following plugin.xml, in order to validate my custom content-type xml2 (xml types) with normal xml validator???
Write now, I am able to open xml2 in XML editor, but not able to validate.
<?eclipse version="3.4"?>
<plugin>
    <extension point="org.eclipse.wst.sse.ui.sourcevalidation">
		<validator
			scope="total"
			class="???"
			id="???">
			<contentTypeIdentifier id="com.xyz.ide.core.contentType.dummy">
				<partitionType id="org.eclipse.wst.xml.XML_DEFAULT">
				</partitionType>
			</contentTypeIdentifier>
		</validator>
	</extension>
	 <extension
         point="org.eclipse.core.runtime.contentTypes">
         <content-type
            base-type="org.eclipse.core.runtime.xml"
            file-extensions="xml2"
            name="xml2"
            priority="normal"
            default-charset="UTF-8"/>
   </extension>
</plugin>
[Updated on: Mon, 30 July 2012 00:50] by Moderator
Re: Associate Custom Content Type with XML Validator. [message #898994 is a reply to message #898993] Mon, 30 July 2012 01:44 Go to previous messageGo to next message
If anyone knows a different way of doing it, please share..thanks
Re: Associate Custom Content Type with XML Validator. [message #899143 is a reply to message #898994] Mon, 30 July 2012 12:30 Go to previous messageGo to next message
Also, if I manually go and add content type through Window->Preferences->Content Type....
That way the validation is still performed.
I am missing some small thing Sad
Re: Associate Custom Content Type with XML Validator. [message #899153 is a reply to message #898993] Mon, 30 July 2012 12:58 Go to previous messageGo to next message
The source (as-you-type) validator class that you're looking for is org.eclipse.wst.xml.ui.internal.validation.DelegatingSourceValidatorForXML. Your id can be whatever you'd like it to be.
Re: Associate Custom Content Type with XML Validator. [message #899166 is a reply to message #899153] Mon, 30 July 2012 14:13 Go to previous messageGo to next message
Just so long as you don't use an ID that exists elsewhere.
Re: Associate Custom Content Type with XML Validator. [message #899193 is a reply to message #899166] Mon, 30 July 2012 21:16 Go to previous messageGo to next message
No Message Body
Re: Associate Custom Content Type with XML Validator. [message #899194 is a reply to message #899193] Mon, 30 July 2012 21:19 Go to previous messageGo to next message
Still no luck guys, I changed to what you specified. Still there is no xml validation??
<plugin>
		<validator
			scope="total"
			 class="org.eclipse.wst.xml.ui.internal.validation.DelegatingSourceValidatorForXML"
			id="org.eclipse.wst.xml.ui.internal.validation.DelegatingSourceValidatorForXML">
				</partitionType>
				<partitionType id="org.eclipse.wst.xml.XML_COMMENT"/>
				<partitionType id="org.eclipse.wst.sse.ST_DEFAULT"/>
		</validator>
	</extension>
   <extension
         <content-type
            name="xml2"
            priority="normal"
   </extension>
</plugin>
Re: Associate Custom Content Type with XML Validator. [message #905848 is a reply to message #898993] Fri, 31 August 2012 03:29 Go to previous message
Have you found a solution?
Previous Topic:How to make Content assist working when editors are inside Composite?
Next Topic:Forcing StructuredTextEditor to recognize XML
Current Time: Sun Jul 20 08:16:09 EDT 2025
Powered by FUDForum. Page generated in 0.03105 seconds
