Home » Modeling » EMF » genmodel is not created because of missing type argument
genmodel is not created because of missing type argument [message #899071] Mon, 30 July 2012 09:28 Go to next message
I created an EMF ecore model and the validation is sucessfully. But when I try to create a genmodel from the ecore model the following error message appears so that I cannot create the genmodel.
"The generic type associated with the 'Sample' classifier should have 1 type argument(s) to match the number of type parameter(s) of the classifier"
This error message is quite vacuous to me. I do not know which generic type is meant. There is no 'Sample' classifier in my model.
Can anybody please help me?
Best regards
Robert
[Updated on: Mon, 30 July 2012 09:30] by Moderator
Re: genmodel is not created because of missing type argument [message #899171 is a reply to message #899071] Mon, 30 July 2012 16:36 Go to previous message
Robert,
Comments below.
On 30/07/2012 3:28 PM, Robert Heinrich wrote:
> when ich try to create a genmodel from the ecore model the following
> classifier"
The *.genmodel is created though right? So the problem is when you open
the *.genmodel, it turns you to the error page. Along the bottom there
are tabs so you can go to the main page and generate more model away.
> type is meant.
If you validate your Ecore model in the Ecore editor, you can click on
the message and you'll be navigated to the object with the problem.
You inherited from another model? There must be a classifier with that
name. It will have one type parameter, and the place where you use it,
there should be a type argument. This error is the same as you'd get in
Java about using a raw type, e.g., when you use just List, instead of
List<SomeType>.
It's hard to be completely accurate without more details from you. Best
you start with validating your Ecore model and at least removing all the
errors; this "raw type" problem is just a warning, not an error.
> Best regards
> Robert
Previous Topic:[xcore] refering to classes in non XCore ecore models
Next Topic:[CDO] Usage of property 'supportingAudits' in server config
Current Time: Sun Jul 20 11:56:34 EDT 2025
Powered by FUDForum. Page generated in 0.03291 seconds
