Home » Modeling » TMF (Xtext) » Couldn't resolve reference to JvmIdentifiableElement 'generateStub'.(XText 2.3 Upgrade)
Couldn't resolve reference to JvmIdentifiableElement 'generateStub'. [message #899041] Mon, 30 July 2012 06:19 Go to next message
Hi All,
I upgraded my XText on eclipse from 2.2.1 to 2.3. After which I had to do quite a number of changes in my code to adapt to the new framework. I could some how resolve most of them but was not able to resolve one particular error
I see in my old code that generateStub in my *.mwe2 file was a reference to method
public boolean setGenerateStub(final boolean generateStub) in SerialzerFragment of XText generator, even though the updated xtext has the same class in the same package and also has the same method but the reference is not resolved Sad.
Any help in this regard would be very much helpful and appreciable. Thanks in advance.
Please let me know if much details required.
Re: Couldn't resolve reference to JvmIdentifiableElement 'generateStub'. [message #899149 is a reply to message #899041] Mon, 30 July 2012 12:45 Go to previous messageGo to next message
this should work. looks like your installation/setup is corrupt.
~Christian
Re: Couldn't resolve reference to JvmIdentifiableElement 'generateStub'. [message #899179 is a reply to message #899041] Mon, 30 July 2012 17:23 Go to previous messageGo to next message
I've had the same when I upgraded to 2.3.0.
Unfortunately, I do not recall what exactly made it disappear.
I suppose it could be related with the fact that Xtend has been split of Xtext - so try to make sure that you have the Xtend SDK 2.3.0 installed in your IDE - the SerializerFragment is resolved as an Xtend class inside org.eclipse.xtext.generator_2.3.0; this class has a setGenerateStub method, so everything looks fine.
Could you check where your SerializerFragment resolves to (the version of the bundle as well as if it is a java class or an xtend class)?
[Updated on: Mon, 30 July 2012 17:25] by Moderator
Re: Couldn't resolve reference to JvmIdentifiableElement 'generateStub'. [message #899239 is a reply to message #899041] Tue, 31 July 2012 04:08 Go to previous messageGo to next message
Thanks for the reply. I guess the 2.3.0 installation of XText was improper. Now I got rid of those errors with a fresh installation however now I have another kind of error
"This expression is not allowed in this context, since it doesn't cause any side effects.".
I did some searching of the same in the bug list and found out that new version complains as I mentioned above. Here is the link
https://bugs.eclipse.org/bugs/show_bug.cgi?id=381770
I see that the bug is resolved, but I could not get the solution. Thanks in advance.
Re: Couldn't resolve reference to JvmIdentifiableElement 'generateStub'. [message #899989 is a reply to message #899239] Fri, 03 August 2012 07:01 Go to previous messageGo to next message
Hi All,
I am awaiting some positive response for the above error. Please let me know. Thanks Smile
Re: Couldn't resolve reference to JvmIdentifiableElement 'generateStub'. [message #899991 is a reply to message #899989] Fri, 03 August 2012 07:15 Go to previous messageGo to next message
there are several bugs around this. since you did not come up with a specific example it is hard to tell if your problem is already fixed. there is e.g. https://bugs.eclipse.org/bugs/show_bug.cgi?id=382208
if you do special things in your Xtend file.
~Christian
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext@itemis.de
Re: Couldn't resolve reference to JvmIdentifiableElement 'generateStub'. [message #899994 is a reply to message #899991] Fri, 03 August 2012 07:30 Go to previous messageGo to next message
This is a sample case from my workspace
def dispatch create eReference : EcoreFactory::eINSTANCE.createEReference mapProperty(MyProperty myproperty) {
eReference.setPropertyAttributes(...)
eReference.containment = false
eReference
Basically, I am returning an eReference in this xtend method, for which my update of XText and Xtend is crying telling me that "This expression is not allowed in this context, since it doesn't cause any side effects."
Hope this helps to better understand my usecase? Thanks Smile
Re: Couldn't resolve reference to JvmIdentifiableElement 'generateStub'. [message #899995 is a reply to message #899994] Fri, 03 August 2012 07:34 Go to previous messageGo to next message
this is 100% the bug i have posted (that is NOT fixed). the workaround is to split dispatch and create
def create eReference : EcoreFactory::eINSTANCE.createEReference mapPropertyInternal(MyProperty myproperty) {
eReference
def dispatch mapProperty(MyProperty myproperty) {
mapPropertyInternal(myproperty)
~Christian
Re: Couldn't resolve reference to JvmIdentifiableElement 'generateStub'. [message #900002 is a reply to message #899995] Fri, 03 August 2012 07:54 Go to previous messageGo to next message
Hi Christian,
Thanks for the reply, but even with the changed implementation as you mentioned, I still get the same error. Sad. Phew!
Re: Couldn't resolve reference to JvmIdentifiableElement 'generateStub'. [message #900005 is a reply to message #900002] Fri, 03 August 2012 08:06 Go to previous message
does it work to leave out the last eReference statement/expression?
~Christian
Previous Topic:Terminal Rule Error
Next Topic:Using variables with predefined functions
Current Time: Sat Jul 19 22:06:02 EDT 2025
Powered by FUDForum. Page generated in 0.03451 seconds
