Home » Modeling » ATL » UML2 to Java Literals
UML2 to Java Literals [message #873492] |
Fri, 18 May 2012 07:12  |
By the advice of Ed Willink (thank again), I should post my last unanswered post here:
--- POST
I am developing a model-based tool, PIM -> PSM -> Code, and I am using EMF ATL to accomplish the M2M transformations. My problem is simple: My ATL mapping works betwen UML2 and Java metamodels, except in Primitive Types.
If some with more experience could look to my files and take a shot, it will help me a lot!
UML metamodel: By URI, but you could use that as reference: UML.ecore;
Java metamodel: Java-20040316.ecore; (To be built gradually);
ATL mapping: UML2JAVA.atl;
My (UML) input Model: exampleUMLModel_PIM.xmi;
My (Java) output Model: out.j2se5; ==> At line 18 it is supposed to have a Primitive Type, right?
tanks in advance
--- Continuation
This is my Atl configuration, hope this help a little more ... Should I need to register something more?
* To change this template, choose Tools | Templates
* and open the template in the editor.
public class UML2_2_JAVA extends AbstractPIMPSM_Factory
private IInjector injector;
private IExtractor extractor;
private IReferenceModel sourceMetamodel;
private IReferenceModel targetMetamodel;
private String transformationFilepath = null;
private String sourceMetaModelFilepath = null;
private String targetMetaModelFilepath = null;
private String sourceDataFilepath = null;
private String targetDataFilepath = null;
private IModel targetModel;
private IModel sourceModel;
private ModelFactory factory;
private ILauncher launcher;
public UML2_2_JAVA()
super();
public IModel getTargetModel()
return this.targetModel;
/// From now on, there are the functions
public void doCore() throws ATLCoreException
CoreService.registerLauncher("EMF-specific VM", EMFVMLauncher.class);
CoreService.registerFactory("EMF", EMFModelFactory.class);
CoreService.registerExtractor("EMF", EMFExtractor.class);
CoreService.registerInjector("EMF", EMFInjector.class);
injector = CoreService.getInjector("EMF");
extractor = CoreService.getExtractor("EMF");
// Defaults
this.factory = CoreService.getModelFactory("EMF");
/*Resource specification*/
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("ecore", new EcoreResourceFactoryImpl());
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("xmi", UMLResource.Factory.INSTANCE);
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
/*Type specification*/
EPackage.Registry.INSTANCE.put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
EPackage.Registry.INSTANCE.put("ecore", EcorePackage.eINSTANCE);
EPackage.Registry.INSTANCE.put("h**p://www.omg.org/spec/UML/20110701", UMLPackage.eINSTANCE);
EPackage.Registry.INSTANCE.put("h**p://www.omg.org/spec/XMI/20110701", UMLPackage.eINSTANCE);
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("j2se5", new EcoreResourceFactoryImpl());
public void doMetaModels(String sourceTargetMMPath) throws ATLCoreException
{ this.doMetaModels(sourceTargetMMPath, null); }
public void doMetaModels(String sourceMMPath, String targetMMPath) throws ATLCoreException
// Metamodels
this.sourceMetaModelFilepath = sourceMMPath;
sourceMetamodel = factory.newReferenceModel();
injector.inject(sourceMetamodel, UMLPackage.eNS_URI);
if(targetMMPath != null) //This means, the metamodel is the same for both models (InputModel & OutputModel)
this.targetMetaModelFilepath = targetMMPath;
targetMetamodel = factory.newReferenceModel();
injector.inject(targetMetamodel, URI.createFileURI(targetMetaModelFilepath).toString());
public void doModels(String sourceDM) throws ATLCoreException
/// Creating models
sourceModel = factory.newModel(sourceMetamodel);
if(this.targetMetamodel == null)
{ targetModel = factory.newModel(this.sourceMetamodel);}
else
{ targetModel = factory.newModel(this.targetMetamodel); }
// Loading existing model
this.sourceDataFilepath = sourceDM;
injector.inject(sourceModel, URI.createFileURI(sourceDM).toString());
public void doTrans(String transformationPath) throws ATLCoreException, MalformedURLException, IOException
// Getting launcher
launcher = (EMFVMLauncher)CoreService.getLauncher("EMF-specific VM");
launcher.initialize(Collections.<String, Object> emptyMap());
// Launching //TODO: REVER ISTO
launcher.addInModel(sourceModel,"IN", "UML");
launcher.addOutModel(targetModel, "OUT", "JAVA");
// the loadModule function requires an absolute path to the ASM file
this.transformationFilepath = transformationPath;
URL asmFile = new File(transformationPath).toURI().toURL();
Object loadedModule = launcher.loadModule(asmFile.openStream());
//launcher.addLibrary("libName", new File("path").toURI().toURL().openStream());
Map <String, Object> optionsTransf = new TreeMap <String, Object>();
optionsTransf.put("showSummary", "true");
optionsTransf.put("printExecutionTime", "true");
optionsTransf.put("continueAfterError", "true");
optionsTransf.put("allowInterModelReferences", "true");
//optionsTransf.put("step", "true");
launcher.launch(ILauncher.DEBUG_MODE, new NullProgressMonitor(), optionsTransf, loadedModule);
* Saving model
public void doSave(String dataTargetfp) throws ATLCoreException
this.targetMetaModelFilepath = dataTargetfp;
//extractor.extract(targetModel, System.out, null);
extractor.extract(targetModel, URI.createFileURI(dataTargetfp).toString());
Re: UML2 to Java Literals [message #899084 is a reply to message #873494] |
Mon, 30 July 2012 10:05  |
HI Rogério Costa,
I am having similar issue with literals, can you tell me what solved your problem, it it is solved.
thanks in advance,
emwedish
[Updated on: Mon, 30 July 2012 10:06] by Moderator
Current Time: Sat Jul 19 06:54:52 EDT 2025
Powered by FUDForum. Page generated in 0.12814 seconds
