Home » Language IDEs » ServerTools (WTP) » Tweaking the JSP include path in Eclipse
Tweaking the JSP include path in Eclipse [message #899032] Mon, 30 July 2012 05:34 Go to next message
I'm currently using a Java project with the following configuration:
- one source folder at '/content'
- JSPs, JS and CSS files are all placed under '/content'
- all JSPs start with a '<%@include file="/global.jsp"%>' directive
- the project is _not_ a web tools project since all our projects are Maven-based and we discourage manual configuration of projects ( see below for more details ).
The main problem that I have is that the @include directive is not getting resolved ( that JSP is just a bunch of taglib declarations and imports, for convenience ).
I did try adding a Dynamic Web Project facet to that project and configuring the content root to be '/content' and the context path '/'. However, that seems overkill to me since:
- I have to ask everyone to perform a manual configuration step ; if they get the paths wrong when configuring the facets there is no UI to fix them; they have to re-import
- I have to disable all validators, including the JS one since they use a lot of CPU and the JS one fails with internal errors
- The import creates unneeded src, META-INF and WEB-INF folders
Given that, I'd like to make Eclipse resolve that import without adding a project nature, and I'm willing to look into all options, including code contributions.
I'd like to hear your thoughts on this though before starting looking at the code though.
Robert
[Updated on: Mon, 30 July 2012 09:27] by Moderator
Re: Tweaking the JSP include path in Eclipse [message #899073 is a reply to message #899032] Mon, 30 July 2012 09:34 Go to previous messageGo to next message
The path resolving could be handled by the m2e-wtp plug-in (http://www.eclipse.org/m2e-wtp/), but I don't have any experience using it. Otherwise, the org.eclipse.wst.common.modulecore.ModuleCoreNature nature in the .project file and the project's .settings/org.eclipse.wst.common.component are really all that's needed to support defining where '/' actually is.
Re: Tweaking the JSP include path in Eclipse [message #899254 is a reply to message #899073] Tue, 31 July 2012 04:51 Go to previous message
Thanks, Nitin.
Previous Topic:J2EE preview
Next Topic:entity expansion limit
Current Time: Sat Jul 19 22:06:40 EDT 2025
Powered by FUDForum. Page generated in 0.04553 seconds
