Home » Modeling » TMF (Xtext) » guava dependencies
guava dependencies [message #898507] Thu, 26 July 2012 09:52 Go to next message
Hi!
Two issues here:
* Are there any plans to update the guava dependency to a newer version? I have a project that uses r11 (possibly soon even r12) and I can't use xtend there because of the conflicting versions.
* There is an older post (http://www.eclipse.org/forums/index.php/mv/msg/266685/766789/#msg_766789) where it was pointed out that some xtext plugins reference guava version 1.0.0, instead of presumably 10.0.1. I can't find a bug report for that and it looks like it's the same in the latest versions. I will file a bug report.
best regards,
Vlad
Re: guava dependencies [message #899014 is a reply to message #898507] Mon, 30 July 2012 03:41 Go to previous messageGo to next message
Hi Vlad,
which problems did you face? IIRC we do not restrict the Guave version
with an upper constraint. Having one that uses 1.0.0 as lower bound by
accident should not cause any trouble, either.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 26.07.12 15:52, schrieb Vlad Dumitrescu:
> Hi!
> Two issues here:
> bug report.
> best regards,
> Vlad
Re: guava dependencies [message #899019 is a reply to message #899014] Mon, 30 July 2012 03:57 Go to previous messageGo to next message
Sebastian Zarnekow wrote on Mon, 30 July 2012 09:41
Hi Vlad,
> bug report.
I couldn't update some plugins and eclipse complained about conflicting versions of the guava plugins, among other things. Unfortunately I didn't save the logs and I have reinstalled everything since then. It could have been a side-effect or something, you are right that the bogus lower-bound should not do any trouble.
Regarding my other question, do you have plans to upgrade guava to r11?
regards,
Vlad
Re: guava dependencies [message #899694 is a reply to message #899019] Wed, 01 August 2012 17:27 Go to previous message
Hello Sebastian,
in xtext.xbase.lib the dependency is set to 10.0.1 which is translated to (10.0.1,11.0.0] until the plugin is released. I have a similar problem in my target, but I can select explicit 10.0.1 as target version. Perhaps no constraint or an explicit upper bound could help.
Benjamin
Previous Topic:how to generate the ecore model from your grammar
Next Topic:quick fix (ISemanticModification) for file with errors?
Current Time: Sat Jul 19 20:56:27 EDT 2025
Powered by FUDForum. Page generated in 0.04429 seconds
