Home » Archived » BIRT » Handling the BIRT Report large amount of Data
Handling the BIRT Report large amount of Data [message #897621] Tue, 24 July 2012 15:19 Go to next message
I am using BIRT 3.7.1. I have one BIRT report(tablular) which has 1700 Pages of data. And it is taking 5 minutes to load. Does anyone has any idea how we can handle this?
Re: Handling the BIRT Report large amount of Data [message #898683 is a reply to message #897621] Fri, 27 July 2012 04:12 Go to previous messageGo to next message
I would be curious to know how long does it take on a such big report, once generated in the Birt Web Viewer, when we just switch to next/previous page? Is it nearly instantaneous or not?
Well, i suppose you should add parameters, in order to address this report in smaller parts. If you absolutely need to get the whole report each time, you could probably generate it daily in PDF format and make it available on a shared intranet resource.
Re: Handling the BIRT Report large amount of Data [message #898804 is a reply to message #898683] Fri, 27 July 2012 12:52 Go to previous message
Once report gets generated in the BIRT Web Viewer, pagination(next/previous) is very fast. We can say its instantaneous.
Previous Topic:Report viewer on Tomcat
Next Topic:RCP Designer 4.2: Script tab is blank
Current Time: Sat Jul 19 19:49:49 EDT 2025
Powered by FUDForum. Page generated in 0.03903 seconds
