Home » Newcomers » Newcomers » application "com.yocos.bootstrap.application" could not be found in the registry
application "com.yocos.bootstrap.application" could not be found in the registry [message #898661] |
Fri, 27 July 2012 02:32  |
hi,
I've download eclips from yoxos on demand, and i am getting an error message :
java.lang.RuntimeException: Application "com.yoxos.bootstrap.application" could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.equinox.app.error, org.eclipse.equinox.p2.artifact.repository.mirrorApplication, org.eclipse.equinox.p2.director.app.application, org.eclipse.equinox.p2.director, org.eclipse.equinox.p2.garbagecollector.application, org.eclipse.equinox.p2.metadata.generator.EclipseGenerator, org.eclipse.equinox.p2.metadata.repository.mirrorApplication, org.eclipse.equinox.p2.publisher.InstallPublisher, org.eclipse.equinox.p2.publisher.ProductPublisher, org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher, org.eclipse.equinox.p2.reconciler.application, org.eclipse.equinox.p2.repository.repo2runnable, org.eclipse.equinox.p2.updatesite.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.CategoryPublisher, org.eclipse.ui.ide.workbench, org.eclipse.update.core.standaloneUpdate, org.eclipse.update.core.siteOptimizer, org.eclipse.ant.ui.antRunner, org.eclipse.pde.build.Build, org.eclipse.jdt.core.JavaCodeFormatter, org.eclipse.emf.codegen.CodeGen, org.eclipse.emf.codegen.JMerger, org.eclipse.emf.codegen.ecore.Generator, org.eclipse.emf.importer.rose.Rose2GenModel, org.eclipse.cdt.core.GeneratePDOM, org.eclipse.cdt.managedbuilder.core.headlessbuild, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:242)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
it's not a version of jdk problem, and i can't find the application missing in the file i've download from yoxos
so where is my error ? or where can i download this application missing somewhere ?
is it an yoxos error ?
Re: application "com.yocos.bootstrap.application" could not be found in the regist [message #898669 is a reply to message #898661] |
Fri, 27 July 2012 02:47  |
You're probably better to ask on a Yoxos-specific forum.
On 27/07/2012 8:32 AM, mutschler claire wrote:
> hi, I've download eclips from yoxos on demand, and i am getting an
> error message :
> at
> at
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> missing somewhere ? is it an yoxos error ?
Current Time: Sun Jul 20 04:20:04 EDT 2025
Powered by FUDForum. Page generated in 0.29876 seconds
