Home » Modeling » TMF (Xtext) » The path is unmapped after changing Directorylayout
The path is unmapped after changing Directorylayout [message #896895] Fri, 20 July 2012 06:32 Go to next message
Hi to anyone,
I have the directorylayout:
Root
- Build
- Plugins
--- Plugin 1
--- Plugin x
- Tests
--- Test-Plugin 1
--- Test-Plugin x
and want to build a ecore-model from xtext-file:
Starting my build in the Build-folder I call mwe-compounds like:
<workflow>
    <property file="org/xtext/example/GenerateMyDsl.properties"/>
    <property name="runtimeProject" value="../Tests/${projectName}"/>
	<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup" platformUri="${runtimeProject}/.." scanClassPath="true"/>
	<component class="org.eclipse.emf.mwe.utils.DirectoryCleaner" directory="${runtimeProject}/src-gen"/>
	<component class="org.eclipse.emf.mwe.utils.DirectoryCleaner" directory="${runtimeProject}.ui/src-gen"/>
	<component class="org.eclipse.xtext.generator.Generator" mergeManifest="false">
		<pathRtProject value="${runtimeProject}"/>
		<pathUiProject value="${runtimeProject}.ui"/>
		<projectNameRt value="${projectName}"/>
		<projectNameUi value="${projectName}.ui"/>
But I get a exception:
Caused by: java.io.IOException: The path '/Plugins/org.eclipse.xtext.xtextdoc/src-gen/org/eclipse/xtext/xtextdoc/xTextDoc/Chapter.java' is unmapped
     [java] 	at org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandlerImpl.createOutputStream(PlatformResourceURIHandlerImpl.java:428)
     [java] 	at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createOutputStream(ExtensibleURIConverterImpl.java:339)
     [java] 	at org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAdapter.createOutputStream(AbstractGeneratorAdapter.java:1440)
     [java] 	at org.eclipse.emf.mwe2.ecore.CvsIdFilteringGeneratorAdapterFactoryDescriptor$IdFilteringGenModelGeneratorAdapterFactory$IdFilteringGenClassAdapter.createOutputStream(CvsIdFilteringGeneratorAdapterFactoryDescriptor.java:73)
     [java] 	at org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAdapter.generateJava(AbstractGeneratorAdapter.java:1104)
with a flat path structure:
Root
- Build
- Project1
- Project2
- TestProject1
- testProject2
this worked.
What do I have to change to make it working with new enviroment?
Thank you for your help
Best regards
Markus
[Updated on: Fri, 20 July 2012 06:33] by Moderator
Re: The path is unmapped after changing Directorylayout [message #898254 is a reply to message #896895] Thu, 26 July 2012 01:09 Go to previous messageGo to next message
Hi again,
does anyone know?
Or is any information missing to answer this question.
Best regards
Markus
Re: The path is unmapped after changing Directorylayout [message #898266 is a reply to message #898254] Thu, 26 July 2012 01:45 Go to previous messageGo to next message
have a look the platform URI stuff in the standalone setup
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: The path is unmapped after changing Directorylayout [message #898396 is a reply to message #898254] Thu, 26 July 2012 06:25 Go to previous messageGo to next message
Hi Christian,
were does the platform URI have to link to?
Re: The path is unmapped after changing Directorylayout [message #898408 is a reply to message #898396] Thu, 26 July 2012 06:45 Go to previous messageGo to next message
Hi have no idea wanted to give a starting point only. If you se it to
the root the sub roots may have to be mentioned in some URIs too
Re: The path is unmapped after changing Directorylayout [message #899401 is a reply to message #898408] Tue, 31 July 2012 13:04 Go to previous message
Ok, thank you anyway,
found another solution, refeactored pathstructure in svn
Previous Topic:interdependence between your Ecore and your Grammar(editor)
Next Topic:scoping problem
Current Time: Sun Jul 20 11:58:36 EDT 2025
Powered by FUDForum. Page generated in 0.04256 seconds
