Home » Eclipse Projects » EclipseLink » MOXy + Tomcat6 + Maven(Howto use moxy with maven and tomcat6)
icon5.gif  MOXy + Tomcat6 + Maven [message #898370] Thu, 26 July 2012 05:34 Go to next message
I'm trying to make a web application which will handle Web Services. To do this I've 3 project on eclipse :
- Core : project with classes and interfaces
- Client : project which depends of the Core (Maven trick)
- Server : project which depends of the core too
I'm trying to set up Moxy in order to remove a cyclic graph error.
This problem comes from 2 classes :
(/src/main/java/core/object/BasicObject)
(/src/main/java/core/object/BasicRefObject)
/src/main/java/core/application/Voltage
/src/main/java/core/application/VoltageValue
package core.object.application;
import java.util.Date;
import java.util.List;
import javax.persistence.Column;
import javax.persistence.Entity;
import javax.persistence.GeneratedValue;
import javax.persistence.GenerationType;
import javax.persistence.Id;
import javax.persistence.JoinColumn;
import javax.persistence.ManyToOne;
import javax.persistence.OneToMany;
import javax.persistence.Table;
import javax.xml.bind.annotation.XmlRootElement;
import org.eclipse.persistence.oxm.annotations.XmlInverseReference;
import org.hibernate.annotations.LazyCollection;
import org.hibernate.annotations.LazyCollectionOption;
import core.object.BasicRefObject;
import core.object.system.User;
@Entity
@Table(name = "Voltage")
@XmlRootElement()
public class Voltage extends BasicRefObject {
	private static final long serialVersionUID = -7590340638662303349L;
	@Id
	@GeneratedValue(strategy = GenerationType.AUTO)
	@Column(name = "id", nullable = false)
	private long id;
	@ManyToOne
	@JoinColumn(name = "creator", nullable = false)
	private User creator;
	@Column(name = "creationDate", nullable = false)
	private Date creationDate;
	@Column(name = "reference", nullable = false, unique = true)
	private String reference;
	@Column(name = "description", nullable = false)
	private String description;
	@LazyCollection(LazyCollectionOption.FALSE)
	@OneToMany(mappedBy = "voltage")
	@XmlInverseReference(mappedBy = "voltage")
	private List<VoltageValue> voltageValueList;
	 * @return the id
	public long getId() {
		return id;
	 * @param id the id to set
	public void setId(long id) {
		this.id = id;
	 * @return the creator
	public User getCreator() {
		return creator;
	 * @param creator the creator to set
	public void setCreator(User creator) {
		this.creator = creator;
	 * @return the creationDate
	public Date getCreationDate() {
		return creationDate;
	 * @param creationDate the creationDate to set
	public void setCreationDate(Date creationDate) {
		this.creationDate = creationDate;
	 * @return the reference
	public String getReference() {
		return reference;
	 * @param reference the reference to set
	public void setReference(String reference) {
		this.reference = reference;
	 * @return the description
	public String getDescription() {
		return description;
	 * @param description the description to set
	public void setDescription(String description) {
		this.description = description;
	 * @return the voltageValueList
	public List<VoltageValue> getVoltageValueList() {
		return voltageValueList;
	 * @param voltageValueList the voltageValueList to set
	public void setVoltageValueList(List<VoltageValue> voltageValueList) {
		this.voltageValueList = voltageValueList;
import core.object.BasicObject;
@Entity
@Table(name = "VoltageValue")
@XmlRootElement()
public class VoltageValue extends BasicObject {
	private static final long serialVersionUID = 5563489030736775097L;
	@Id
	private long id;
	@ManyToOne
	@ManyToOne
	@JoinColumn(name = "voltage", nullable = false)
	private Voltage voltage;
	@ManyToOne
	@JoinColumn(name = "torque", nullable = false)
	private Torque torque;
	@ManyToOne
	@JoinColumn(name = "typeOfVoltageValue", nullable = false)
	private TypeOfVoltageValue typeOfVoltageValue;
	@Column(name = "frequency", nullable = false)
	private double frequency;
	@Column(name = "value", nullable = false)
	private double value;
	 * @return the id
		return id;
		this.id = id;
		return creator;
	public Voltage getVoltage() {
		return voltage;
	 * @param voltage the voltage to set
	public void setVoltage(Voltage voltage) {
		this.voltage = voltage;
	 * @return the torque
	public Torque getTorque() {
		return torque;
	 * @param torque the torque to set
	public void setTorque(Torque torque) {
		this.torque = torque;
	 * @return the typeOfVoltageValue
	public TypeOfVoltageValue getTypeOfVoltageValue() {
		return typeOfVoltageValue;
	 * @param typeOfVoltageValue the typeOfVoltageValue to set
	public void setTypeOfVoltageValue(TypeOfVoltageValue typeOfVoltageValue) {
		this.typeOfVoltageValue = typeOfVoltageValue;
	 * @return the frequency
	public double getFrequency() {
		return frequency;
	 * @param frequency the frequency to set
	public void setFrequency(double frequency) {
		this.frequency = frequency;
	 * @return the value
	public double getValue() {
		return value;
	 * @param value the value to set
	public void setValue(double value) {
		this.value = value;
And set up Moxy, I put a jaxb.properties in /src/main/resources and I put this in the pom.xml of the Core
<plugin>
				<artifactId>maven-resources-plugin</artifactId>
				<version>2.5</version>
				<executions>
					<execution>
						<id>copy-resources</id>
						<phase>validate</phase>
						<goals>
							<goal>copy-resources</goal>
						</goals>
						<configuration>
							<outputDirectory>${basedir}\target\classes\core\object\application\</outputDirectory>
							<resources>
								<resource>
									<directory>${basedir}\src\main\resources\</directory>
									<includes>
										<include>jaxb.properties</include>
									</includes>
								</resource>
							</resources>
						</configuration>
					</execution>
				</executions>
			</plugin>
But it doesn't work.
So I tried to put this on my web.xml (Server)
    <env-entry>
    	<env-entry-name>javax.xml.bind.JAXBContext</env-entry-name>
    	<env-entry-type>java.lang.String</env-entry-type>
    	<env-entry-value>org.eclipse.persistence.jaxb.JAXBContextFactory</env-entry-value>
    </env-entry>
    <env-entry>
    	<env-entry-name>javax.xml.bind.context.factory</env-entry-name>
    </env-entry>
But it doesn't work anymore...
What's the best way make it work ?
Re: MOXy + Tomcat6 + Maven [message #898817 is a reply to message #898370] Fri, 27 July 2012 14:33 Go to previous message
Hello Jeremie,
Is your question essentially how to get the jaxb.properties file in the correct location (same package as the model classes) in the deployment archive?
-Blaise
Previous Topic:@MappedSuperclass with Generic types
Next Topic:Search Query Error
Current Time: Sat Jul 19 19:39:26 EDT 2025
Powered by FUDForum. Page generated in 0.63424 seconds
