Home » Modeling » TMF (Xtext) » Updating resource description takes forever(Problems with xtext/emf)
Re: Updating resource description takes forever [message #898079 is a reply to message #898077] |
Wed, 25 July 2012 14:17   |
Here the corresponding stack trace
Thread [Worker-4] (Suspended)
owns: BufferedInputStream (id=674)
owns: HttpURLConnection (id=675)
owns: ClusteringBuilderState (id=68)
SocketInputStream.socketRead0(FileDescriptor, byte[], int, int, int) line: not available [native method]
SocketInputStream.read(byte[], int, int, int) line: not available
SocketInputStream.read(byte[], int, int) line: not available
BufferedInputStream.fill() line: not available
BufferedInputStream.read1(byte[], int, int) line: not available
BufferedInputStream.read(byte[], int, int) line: not available
HttpClient.parseHTTPHeader(MessageHeader, ProgressSource, HttpURLConnection) line: not available
HttpClient.parseHTTP(MessageHeader, ProgressSource, HttpURLConnection) line: not available
HttpURLConnection.getInputStream() line: not available
URIHandlerImpl.createInputStream(URI, Map<?,?>) line: 172
XtextResourceSet$1(ExtensibleURIConverterImpl).createInputStream(URI, Map<?,?>) line: 354
SAXXMIHandler(XMLHandler).resolveEntity(String, String) line: 804
EntityResolverWrapper.resolveEntity(XMLResourceIdentifier) line: not available
XMLEntityManager.resolveEntityAsPerStax(XMLResourceIdentifier) line: not available
XMLEntityManager.startEntity(String, boolean) line: not available
XMLDTDScannerImpl.startPE(String, boolean) line: not available
XMLDTDScannerImpl.skipSeparator(boolean, boolean) line: not available
XMLDTDScannerImpl.scanDecls(boolean) line: not available
XMLDTDScannerImpl.scanDTDExternalSubset(boolean) line: not available
XMLDocumentScannerImpl$DTDDriver.dispatch(boolean) line: not available
XMLDocumentScannerImpl$DTDDriver.next() line: not available [local variables unavailable]
XMLDocumentScannerImpl$PrologDriver.next() line: not available
XMLDocumentScannerImpl.next() line: not available
XMLDocumentScannerImpl(XMLDocumentFragmentScannerImpl).scanDocument(boolean) line: not available
XIncludeAwareParserConfiguration(XML11Configuration).parse(boolean) line: not available
XIncludeAwareParserConfiguration(XML11Configuration).parse(XMLInputSource) line: not available
SAXParserImpl$JAXPSAXParser(XMLParser).parse(XMLInputSource) line: not available
SAXParserImpl$JAXPSAXParser(AbstractSAXParser).parse(InputSource) line: not available
SAXParserImpl$JAXPSAXParser.parse(InputSource) line: not available
SAXParserImpl.parse(InputSource, DefaultHandler) line: not available
XMILoadImpl(XMLLoadImpl).load(XMLResource, InputStream, Map<?,?>) line: 175
XMIResourceImpl(XMLResourceImpl).doLoad(InputStream, Map<?,?>) line: 240
XMIResourceImpl(ResourceImpl).load(InputStream, Map<?,?>) line: 1505
SAXXMIHandler(XMLHandler).getPackageForURI(String) line: 2536
SAXXMIHandler(XMLHandler).getFactoryForPrefix(String) line: 2416
SAXXMIHandler(XMLHandler).createObjectByType(String, String, boolean) line: 1293
SAXXMIHandler(XMLHandler).createTopObject(String, String) line: 1462
SAXXMIHandler(XMLHandler).processElement(String, String, String) line: 1013
SAXXMIHandler(XMIHandler).processElement(String, String, String) line: 77
SAXXMIHandler(XMLHandler).startElement(String, String, String) line: 995
SAXXMIHandler(XMLHandler).startElement(String, String, String, Attributes) line: 706
SAXXMIHandler(XMIHandler).startElement(String, String, String, Attributes) line: 163
SAXParserImpl$JAXPSAXParser(AbstractSAXParser).startElement(QName, XMLAttributes, Augmentations) line: not available
XMLDTDValidator.startElement(QName, XMLAttributes, Augmentations) line: not available
XMLDocumentScannerImpl(XMLDocumentFragmentScannerImpl).scanStartElement() line: not available
XMLDocumentScannerImpl$ContentDriver.scanRootElementHook() line: not available
XMLDocumentScannerImpl$ContentDriver(XMLDocumentFragmentScannerImpl$FragmentContentDriver).next() line: not available
XMIResourceImpl(ResourceImpl).load(Map<?,?>) line: 1284
XtextResourceSet(ResourceSetImpl).demandLoad(Resource) line: 259
XtextResourceSet(ResourceSetImpl).demandLoadHelper(Resource) line: 274
XtextResourceSet.getResource(URI, boolean) line: 159
XtextResourceSet(ResourceSetImpl).getEObject(URI, boolean) line: 220
EcoreUtil.resolve(EObject, ResourceSet) line: 197
EcoreUtil.resolve(EObject, EObject) line: 257
EAttributeImpl(BasicEObjectImpl).eResolveProxy(InternalEObject) line: 1473
EAttributeImpl(ETypedElementImpl).getEType() line: 315
EAttributeImpl.eGet(int, boolean, boolean) line: 240
EAttributeImpl(BasicEObjectImpl).eGet(EStructuralFeature, boolean, boolean) line: 1011
EAttributeImpl(BasicEObjectImpl).eGet(EStructuralFeature, boolean) line: 1003
ENamedElementImpl$2$1(EContentsEList$FeatureIteratorImpl<E>).hasNext() line: 403
EcoreUtil2.resolveCrossReferences(EObject, CancelIndicator) line: 512
EcoreUtil2.resolveAll(Resource, CancelIndicator) line: 483
EcoreUtil2.resolveLazyCrossReferences(Resource, CancelIndicator) line: 496
ClusteringBuilderState.doUpdate(BuildData, ResourceDescriptionsData, IProgressMonitor) line: 204
ClusteringBuilderState(AbstractBuilderState).update(BuildData, IProgressMonitor) line: 105
XtextBuilder.doBuild(ToBeBuilt, IProgressMonitor, IXtextBuilderParticipant$BuildType) line: 159
XtextBuilder.fullBuild(IProgressMonitor, boolean) line: 188
XtextBuilder.build(int, Map, IProgressMonitor) line: 85
BuildManager$2.run() line: 728
SafeRunner.run(ISafeRunnable) line: 42
BuildManager.basicBuild(int, IncrementalProjectBuilder, Map<String,String>, MultiStatus, IProgressMonitor) line: 199
BuildManager.basicBuild(IBuildConfiguration, int, IBuildContext, ICommand[], MultiStatus, IProgressMonitor) line: 239
BuildManager$1.run() line: 292
BuildManager.basicBuild(IBuildConfiguration, int, IBuildContext, MultiStatus, IProgressMonitor) line: 295
BuildManager.basicBuildLoop(IBuildConfiguration[], IBuildConfiguration[], int, MultiStatus, IProgressMonitor) line: 351
BuildManager.build(IBuildConfiguration[], IBuildConfiguration[], int, IProgressMonitor) line: 374
AutoBuildJob.doBuild(IProgressMonitor) line: 143
AutoBuildJob.run(IProgressMonitor) line: 241
Worker.run() line: 54
Current Time: Sun Jul 20 03:00:51 EDT 2025
Powered by FUDForum. Page generated in 0.06008 seconds
