Home » Archived » BIRT » Dynamic text with page number
Dynamic text with page number [message #897261] Mon, 23 July 2012 08:45 Go to next message
Yo,
I need print a page number concatenated with columns from database in dynamic text.
The autotext - "page Number" and "confidential - Page#" - don't solve my problems 'cause the text can (or not) have a line break.
When i put the "pageNumber" doesnt work (stay ever in 1).Create a variable and try iterate on pagebreak from layout too.
Need do it in Masterpage (grid on header).
Suggests?
- Birt Version: 3.7.2
- Format output: pdf
Re: Dynamic text with page number [message #897401 is a reply to message #897261] Mon, 23 July 2012 21:47 Go to previous messageGo to next message
How are you running the report? Are you using the viewer or the Report
Engine? Try using the pageNumber in and then in the designer run it to
the viewer then export to pdf.
Jason
On 7/23/2012 8:45 AM, Arkon Javia wrote:
> Yo,
> dynamic text. The autotext - "page Number" and "confidential - Page#" -
> Suggests?
Re: Dynamic text with page number [message #897520 is a reply to message #897401] Tue, 24 July 2012 07:58 Go to previous messageGo to next message
Doesn't work.
I had used export in pdf always (need this format) and pageNumber don't iterate.
Re: Dynamic text with page number [message #897629 is a reply to message #897520] Tue, 24 July 2012 15:57 Go to previous messageGo to next message
Can you reproduce in a sample report using the sample db to show the
issue? When you tested you previewed using the web viewer which shows
it in html and then exported from the web viewer menu to pdf?
Jason
On 7/24/2012 7:58 AM, Arkon Javia wrote:
> Doesn't work.
> iterate.
Re: Dynamic text with page number [message #897635 is a reply to message #897629] Tue, 24 July 2012 16:22 Go to previous messageGo to next message
The same happened when I tried web viewer and latter export pdf.
I need do it like in sample (annex), in masterPage. Variables too are accepted.
PS:(birt 3.7.2)
[Updated on: Tue, 24 July 2012 16:22] by Moderator
Re: Dynamic text with page number [message #897639 is a reply to message #897635] Tue, 24 July 2012 16:53 Go to previous message
Look at the attached modified example. Keep in mind though the way you
have all the text in one field it will only produce 2 pages in html and
this will not match the pdf which will be 4. If you had this is in a
list or table rows html and pdf would match. Or string split the text
into multiple grid rows.
Jason
Re: Dynamic text with page number [message #897640 is a reply to message #897635] Tue, 24 July 2012 16:53 Go to previous message
Jason
Previous Topic:How to hide crosstab columns at runtime (in Excel)
Next Topic:Placing library in RAP environment
Current Time: Sun Jul 20 02:58:31 EDT 2025
Powered by FUDForum. Page generated in 0.03779 seconds
