Home » Language IDEs » C / C++ IDE (CDT) » Eclipse cdt debugging an executable within a shell script
Eclipse cdt debugging an executable within a shell script [message #896341] Wed, 18 July 2012 02:56 Go to next message
I recently started using Eclipse CDT on Linux and like it a lot!!!
I am able to find an answer to almost everything.
I am unable to invoke debugger on a simple executable and I need to do it after running a quite big shell script which sets many environment variables.
My question is simply how to do it, so that eventually, I'll be able to invoke the debugger (GDB) where all environment variables are set by some pre-running shell script.
Alternatively, how do setup a script which - as first stage - sets up the environment, and eventually invokes the Eclipse CDT debugger.
Your assistance is much appreciated.
Regards, -Zvika
Re: Eclipse cdt debugging an executable within a shell script [message #896372 is a reply to message #896341] Wed, 18 July 2012 04:24 Go to previous messageGo to next message
You have two possibilities.
1) Adapt your Debug Launch Configuration so it has all the environment variables you need and then start your executable directly
2) Adapt your Debug Launch Configuration so that it calls your shell script.
Here is an example for KDE and konsole:
- Set C/C++ application to "/usr/bin/konsole"
- as argument use
-e "bash -c \"./myshellscript.sh; exec bash\""
(the quotes are important!)
Re: Eclipse cdt debugging an executable within a shell script [message #897381 is a reply to message #896372] Mon, 23 July 2012 16:49 Go to previous messageGo to next message
Hi Axel,
I tried to follow your receipt, and was kind of stuck. Eventually, I was able to do something along your lines which was good enough for me. I'll have to explore more to make this working stable enough.
Thanks for your advice.
-Zvika
Re: Eclipse cdt debugging an executable within a shell script [message #1768211 is a reply to message #897381] Fri, 14 July 2017 13:30 Go to previous message
what final solution you adopted?
I'm stuck with the same problem.
Previous Topic:Cross GCC
Next Topic:indexer doesn't track active configuration for #ifdefs
Current Time: Sat Jul 19 14:56:02 EDT 2025
Powered by FUDForum. Page generated in 0.03712 seconds
