Home » Modeling » TMF (Xtext) » embedded languages
embedded languages [message #897294] |
Mon, 23 July 2012 10:05  |
Hi!
I have a faint memory that this was discussed before, but can't find a reference. [Excuse: I just got back from vacation]
Is it possible to handle multiple languages in a single file, assuming they are easily separated lexically (for example, in different document partitions)? One example is javadoc-style comments; another would be code embedded in a string.
Doing syntax highlighting is relatively easy, the comment/string/whatever token can be parsed and the result can be used in the semantic highlight operation. What about full integration (completion, cross-references, etc)?
When I saw the EmbeddedEditor class, I thought this could be it, but I suppose it refers to embedding it in another UI widget than an Editor... Theoretically, maybe it could be possible to use it within a part of an Editor, having all UI elements first detect which language support they should use at the current cursor position.
Maybe the amount of work needed would be prohibitive, but on the other hand for not many years ago I would have said the same about something like Xtext
best regards,
Vlad
Re: embedded languages [message #897313 is a reply to message #897294] |
Mon, 23 July 2012 10:52   |
On 2012-23-07 16:05, Vlad Dumitrescu wrote:
> Hi!
Possible = yes, but not explicitly supported in any way.
I imagine host language would simply recognize an embedded sequence as
Embedded, and put it in a partition. A second parser for the embedded
language kicks in after model is linked - this validates and links the
second language. ResourceDescription for the host language is extended
to also describe the embedded language. When parsing the embedded
language, it probably needs to understand the imports/visibility in the
host language.
> like Xtext :)
Does not sound too difficult actually...
> best regards,
> Vlad
Re: embedded languages [message #897332 is a reply to message #897313] |
Mon, 23 July 2012 11:43   |
Hi Henrik and thanks for the answer.
It doesn't sound too difficult indeed, but I think it is more difficult than that
There's a difference between manually adding support for language A to embed snippets in language B or C, but generic support has many hard cases (like for example, even language B could embed language D or, horror!, language A).
In addition, there are some semantic question marks too: for example, language A treats each embedded snippet as standalone, but language B might want to group them together...
From a technical point of view, EmbeddedEditor is a good candidate for a starting point: it can use resources that are not files. If one restricts the embedding to one level, I think that the main missing part is an ISourceViewer that links a document partition and doesn't require an own text widget. Or maybe one could define language B/C in a way that sees the language A parts as whitespace and then the same sourceviewer/text widget can be used? Then we "only" need to be able to connect all the languages to the editor and have logic to detect which language is active at each position...
Well, I am just thinking loud. Maybe there isn't enough interest to make this happen, but it certainly would be very cool!
best regards,
Vlad
Re: embedded languages [message #897359 is a reply to message #897332] |
Mon, 23 July 2012 14:29   |
Vlad, Henrik,
the preferences page for template proposals actually does something
similar. It mixes velocity-like tokens with your language tokens. You
may want to dive into that code to get an idea on how to achieve that.
Unfortunately it is not API nor documented in a meaningful manner but
more the result of a very small pet project that I did two years ago.
Sebastian
Am 23.07.12 17:43, schrieb Vlad Dumitrescu:
> than that :)
> this happen, but it certainly would be very cool! :)
> best regards,
> Vlad
Re: embedded languages [message #897510 is a reply to message #897489] |
Tue, 24 July 2012 06:37  |
I also have a use case.
In VClipse (www.vclipse.org) we implemented DSLs for describing product models in SAP Variant Configuration. This includes descriptions of objects and their relationships (in a language invented by us) and dependency code (in languages invented by SAP). Our first approach was to put all languages into one. However, this has some severe drawbacks, since even the lexical syntax is different (different keywords, keywords in one language might be identifiers in the other, different comment syntax, ...). In the last time we split these languages into several ones and separated the information into several files. So we do not embed anymore.
However, there is one case of dependency code which I really like to have embedded in the language for describing objects: there might be some simple code objects attached to various objects which do not have a global name in SAP and for which I do not want to have a separate file. This is like having short JavaScript code snippets as values of HTML attributes (this is yet another use case).
Unfortunately, we do not have money to invest in such a development...
Current Time: Sat Jul 19 15:36:35 EDT 2025
Powered by FUDForum. Page generated in 0.04697 seconds
