Home » Eclipse Projects » Standard Widget Toolkit (SWT) » drag & drop: source and target are the same
drag & drop: source and target are the same [message #897041] Fri, 20 July 2012 18:29 Go to next message
I try to learn SWT with the collection of snippets. I have a question concerning the topic of drag & drop:
In the snippets (e.g. Snippet78.java) the DragSource finishes the drag by comparing event.detail (in DragSourceListener::dragFinished()) with DND.DROP_MOVE and removes the value if the operation was a DND.DROP_MOVE. But my problem happens, when the source is the target at the same time. For example, when I try to drag the text of the left label (Snippet78.java) to itself: the text deletes itself, which should not be. In line 71 I could add something like this:
if (((String) event.data).equals(((Label)target.getControl()).getText())) {
    event.detail = DND.DROP_NONE;
but in this case, I would have another problem:
If I copy the text of the label in a way, that the text of the right label is the same as the text of the left label, and after this, I want to move the text of the right label to the left, the text of the right label should disappear, but it doesn't. ...?
Re: drag & drop: source and target are the same [message #897071 is a reply to message #897041] Sat, 21 July 2012 08:56 Go to previous messageGo to next message
Hi Andreas,
if you do that as you wrote, the right label shouldn't disappear because you set the event.detail to DND.DROP_NONE and in the right label's DragSourceListener you can see
public void dragFinished(DragSourceEvent event) {
    if (event.detail == DND.DROP_MOVE)
	label.setText ("");
the condition is not satisfied and so the text is left as is.
Re: drag & drop: source and target are the same [message #897078 is a reply to message #897071] Sat, 21 July 2012 09:27 Go to previous messageGo to next message
Yes, exactly. But I would like to have this behaviour:
  • If I had "TEXT" on the left side and "TEXT" on the right side, and I move the left text to the right side, the left text should disappear.
  • If I had "TEXT" on the left side and "" on the right side, and I move the left side to the left (source == target), the text should remain.
I don't know, how to program this behaviour... Confused
P.S.: My english is really awfull, so I show you my intention with pictures. I want to change the Snippet78.java so that the program has this behaviour:
  1. index.php/fa/10800/0/
  2. index.php/fa/10801/0/
  3. index.php/fa/10802/0/
I think it should be easy, but I am too stupid Wink
  • Attachment: drag1.png
    (Size: 3.36KB, Downloaded 588 times)
  • Attachment: drag2.png
    (Size: 3.43KB, Downloaded 576 times)
  • Attachment: drag3.png
    (Size: 3.40KB, Downloaded 597 times)
[Updated on: Sun, 22 July 2012 05:56] by Moderator
Re: drag & drop: source and target are the same [message #897140 is a reply to message #897078] Sun, 22 July 2012 06:57 Go to previous messageGo to next message
Don't worry about your English, I think it's better than mine Razz
Anyway, it seems to me impossible accomplish your needs. Since you have no information about the target control in a DragSourceListener,
you simply can't know whether the target is the source.
My suggestion is to cancel the DND operation if the target text is the same as the dropped data
target.addDropListener (new DropTargetAdapter() {
    public void drop(DropTargetEvent event) {
	if (event.data == null || event.data.equals(label.getText())) {
	    return;
	label.setText ((String) event.data);
so it's exactly the same you have mentioned in your first post. It just doesn't met your third requirement.
Re: drag & drop: source and target are the same [message #897170 is a reply to message #897140] Sun, 22 July 2012 18:35 Go to previous messageGo to next message
Hi Jan,
thank you for your answer. I thougt, it would be possible. Sad But if you find a way to outfox SWT, feel free to post it... Razz
Re: drag & drop: source and target are the same [message #897376 is a reply to message #897170] Mon, 23 July 2012 16:23 Go to previous message
I changed the code to:
package org.eclipse.swt.snippets;
import org.eclipse.swt.*;
import org.eclipse.swt.dnd.*;
import org.eclipse.swt.layout.*;
import org.eclipse.swt.widgets.*;
public class Snippet78 {
    Display display = new Display();
    final Shell shell = new Shell(display);
    shell.setLayout(new FillLayout());
    final Label label1 = new Label(shell, SWT.BORDER);
    label1.setText("TEXT");
    final Label label2 = new Label(shell, SWT.BORDER);
    setDragDrop(label1);
    setDragDrop(label2);
    shell.setSize(200, 200);
    shell.open();
    while (!shell.isDisposed()) {
        if (!display.readAndDispatch())
            display.sleep();
    display.dispose();
static Label sourceLabel;
public static void setDragDrop(final Label label) {
    Transfer[] types = new Transfer[] { TextTransfer.getInstance() };
    int operations = DND.DROP_MOVE | DND.DROP_COPY | DND.DROP_LINK;
    final DragSource source = new DragSource(label, operations);
    source.setTransfer(types);
    source.addDragListener(new DragSourceListener() {
        public void dragStart(DragSourceEvent event) {
            event.doit = (label.getText().length() != 0);
        public void dragSetData(DragSourceEvent event) {
            sourceLabel = label;
            event.data = label.getText();
                label.setText("");
    DropTarget target = new DropTarget(label, operations);
    target.setTransfer(types);
    target.addDropListener(new DropTargetAdapter() {
                    label == sourceLabel) {
                return;
            label.setText((String) event.data);
This seems to fit my intention: All of the three conditions are met. But I am not sure, if this is really the best way.
[Updated on: Tue, 24 July 2012 09:16] by Moderator
Previous Topic: mandatory text box
Next Topic:SWT multiline table with rows of different sizes
Current Time: Sat Jul 19 07:58:34 EDT 2025
Powered by FUDForum. Page generated in 0.28357 seconds
