Home » Newcomers » Newcomers » Juno Tab Problem
Juno Tab Problem [message #896618] Thu, 19 July 2012 03:32 Go to next message
Hi there,
I have a problem with Eclipse Juno. If I have more than one file openend, I have a tab focus problem. Sometimes if I use the delete key or ctr + v the operation is done in the tab that was selected before the one that has the actual focus. I can type letters normal but if I use one of the control key combinations or delete this will happen in another tab.
I tried Juno x64 and x86 on Win 7.
Greetings,
Mirco
Re: Juno Tab Problem [message #896783 is a reply to message #896618] Thu, 19 July 2012 14:03 Go to previous messageGo to next message
Are these XML files when Android is installed? They have a fix for that, coming soon.
If not, what kind of files? What were you doing?
PW
Re: Juno Tab Problem [message #896905 is a reply to message #896783] Fri, 20 July 2012 07:42 Go to previous messageGo to next message
Hi Paul,
you are right, these are XML files and it happens by developing android apps. So I will wait for the fix. Thanks for the info!
Greetings,
Mirco
Re: Juno Tab Problem [message #898140 is a reply to message #896905] Wed, 25 July 2012 17:37 Go to previous message
Hi Paul,
I need your help
http://www.eclipse.org/forums/index.php/t/368193/
Greetings
Previous Topic:Java Policy settings for AspectJ in Websphere
Next Topic:Eclipse acting differently on two pc's
Current Time: Sun Jul 20 10:21:11 EDT 2025
Powered by FUDForum. Page generated in 0.08836 seconds
