Home » Language IDEs » C / C++ IDE (CDT) » Juno CDT discovery not working(Using an Microware/Radisys compiler with make environment)
icon5.gif  Juno CDT discovery not working [message #896851] Fri, 20 July 2012 03:09 Go to next message
I'm trying to use Eclipse CDT with my make environment. Using the "Makefile Project with Existing Code" it was easy to set up the compilation part.
Now I'm trying to get the discovery part working and am struggling with this option.
1) I'm unaware of the difference between the "Project Settings -> C/C++ Build -> Discovery Options" and "C/C++ General -> Preprocessor Include Paths, Macros, etc. -> Providers Tab"
2) The compiler I am using in the make environment is a cross compiler by Microware (nowadays Radisys) and thus I changed the compiler invocation command to "xcc", which is the executable and included in the path environment.
If I understand the invocation commands for gcc correct, they intend to get the defines and include paths which are standard for the compiler. So I changed those to the xcc arguments, that provide this information (and tested it in the console compiling the empty spec.c file provided by Eclipse).
3) Unfortunately after a clean build (I can see the xcc commands in the output console with the includes (-v) and defines (-d)) the "C/C++ General -> Paths and Symbols" as well as the "C/C++ General -> Preprocessor Include Paths, Macros, etc. -> Entries Tab" is still empty.
I tried several toolchain options and Discovery profiles as I'm unsure which one to use with my toolchain.
Any help is appreciated! Thanks in advance!
Re: Juno CDT discovery not working [message #896999 is a reply to message #896851] Fri, 20 July 2012 14:18 Go to previous messageGo to next message
cdt discovery wrote on Fri, 20 July 2012 03:09
"Discovery Options" is deprecated and going to be phased out.
Where did you add this "xcc" invocation? Go to "Preprocessor Include Paths" tab "Providers" and make sure "CDT GCC Builtin Settings" enabled. After that change the command in the provider options. You may need to go to "Workspace Settings" link as instructed.
You can also "Allocate console" in the provider options to check output. This console is different from build console. You can find it in "Display Selected Console" button on the toolbar of the Console View. What is the output, is it the same format as GCC?
Andrew
Re: Juno CDT discovery not working [message #897188 is a reply to message #896999] Mon, 23 July 2012 01:40 Go to previous messageGo to next message
Andrew Gvozdev wrote on Fri, 20 July 2012 14:18
Does that mean I should uncheck "Automate discovery of paths and symbols" in the "Discovery Options" or is the setting already ignored?
Originally I put the "xcc" invocation on the "Discovery Options" page as well as on "C/C++ General -> Preprocessor Include Paths, Macros, etc. -> Entries Tab -> CDT GCC Build Output Parser" In the "CDT GCC Builtin Settings" I have "${COMMAND} -P -b -pp ${INPUTS}" which I thought would take the invocation command and use the currently compiled file of the make environment.
I have "CDT User Setting Entries" enabled but with "Share setting entries between projects" and "Store entries in project settings folder" unticked.
Also the "CDT GCC Build Output Parser" with the invocation mentioned above, also both settings unticked, container is project, heuristics are enabled and enable language settings also enabled.
"CDT GCC Builtin Compiler Settings" also both top boxes unticked, "Command" has been tried with "${COMMAND} -P -b -pp ${INPUTS}" and "xcc -P -b -pp ${INPUTS}".
"CDT Managed Build Settings Entries" have been enabled.
Even though I enabled this option, I only get the "CDT Global Build Console" and the project specific build console. So it seems, the invocation fails. With a different setting (maybe toolchain, or whatever I tried already) I could see this console window - however it was empty then as well.
Thanks so far!
Edit:
The "Preferences -> C/C++ -> Build -> Settings" still listed gcc, however changing that didn't improve the situation.
At the moment I configured the project for "Cross GCC" and "Gnu make builder".
[Updated on: Mon, 23 July 2012 01:57] by Moderator
Re: Juno CDT discovery not working [message #897232 is a reply to message #897188] Mon, 23 July 2012 06:13 Go to previous messageGo to next message
Update:
I modified the field "Compiler Command pattern" from "xcc" to "=(xcc)" and made the project's "CDT GCC Build Output Parser" shared which improved the situation a little bit.
Now I get some output in the "Builtin Compiler Settings GNU C" Console.
12:03:28 **** Running scanner discovery: CDT GCC Builtin Compiler Settings ****
I can see the command I expected xcc -P -b -pp <My Path>/spec.c and the compiler's standard include paths and defines are returned (exit code 0).
However, the entries in the project settings "C/C++ General -> Preprocessor Include Paths, Macros, etc. -> Entries Tab" are still not filled with entries and abviously once I right-click on the project and click "Index -> Rebuild" or "Index -> Freshen All Files" the types are still unresolved and unknown.
Re: Juno CDT discovery not working [message #897340 is a reply to message #897232] Mon, 23 July 2012 12:24 Go to previous messageGo to next message
Can you post the output? Perhaps the output is different from that of gcc and the parser cannot handle it?
Andrew
Re: Juno CDT discovery not working [message #897466 is a reply to message #897340] Tue, 24 July 2012 04:28 Go to previous messageGo to next message
Sure. The xcc gets its include paths with -v parameter which I thought may be causing trouble, but the invocation command returns standard -I and -D. Is there anywhere (except source) where one can see or modify the pattern just like the error parsers?
Note: I removed some include paths and defines since they are of the same kind.
Invocation command:
10:12:05 **** Running scanner discovery: CDT GCC Builtin Compiler Settings ****
xcc -b -pp C:/Programme/Eclipse/workspace/.metadata/.plugins/org.eclipse.cdt.managedbuilder.core/spec.c
"cpfe -m --target=0 -Ic:\OS\SRC\DEFS --translate_names_1 -D_UCC -D_MAJOR_REV=2 -D_OSK -w --Extended_ANSI -E -P C:/Programme/Eclipse/workspace/.metadata/.plugins/org.eclipse.cdt.managedbuilder.core/spec.c"
exit status = 0
Build command:
xcc.exe -v=C:\OS\COMP\defs -a -r -eas=P:\Some\Other\Path -tp=403,ldlcd -td=c:\tmp -dLIB_VERS="123-45.678.111xx" P:\Path\To\File\src\MyFile.c
Re: Juno CDT discovery not working [message #897584 is a reply to message #897466] Tue, 24 July 2012 11:24 Go to previous messageGo to next message
cdt discovery wrote on Tue, 24 July 2012 04:28
exit status = 0
Is that all you are getting in the output? That is not going to get parsed. "GCC Builtin Compiler Settings" parser is expecting output like that of GCC:
#include "..." search starts here:
#include <...> search starts here:
c:/MinGW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/c++/3.4.5
c:/MinGW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/c++/3.4.5/mingw32
c:/MinGW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/c++/3.4.5/backward
c:/MinGW/bin/../lib/gcc/mingw32/3.4.5/include
End of search list.
#define __GNUG__ 3
#define __GNUC_MINOR__ 4
#define __GNUC_PATCHLEVEL__ 5
#define __SIZE_TYPE__ unsigned int
#define __PTRDIFF_TYPE__ int
Andrew
Re: Juno CDT discovery not working [message #897978 is a reply to message #897584] Wed, 25 July 2012 10:38 Go to previous messageGo to next message
Okay, so I guess there is no easy way to modify the output handling as in modify the pattern to recognize include paths and defines?
Since I have no control over the compiler's output I would either have to parse it to generate the requested output or if possible provide/get a plugin, right?
Nevertheless thanks a lot for your help on this!
Re: Juno CDT discovery not working [message #898081 is a reply to message #897978] Wed, 25 July 2012 14:23 Go to previous messageGo to next message
There is another parser that handles similar output, "XLC Builtin Compiler Settings". I tried to feed your output and luckily it took it as its own. Try it.
Andrew
icon14.gif  Re: Juno CDT discovery not working [message #898319 is a reply to message #897466] Thu, 26 July 2012 04:10 Go to previous messageGo to next message
Thank you!! That did the job for the builtin compiler settings!
(Just in case someone else runs into the same problem: I installed "XLC C/C++ Compiler Support" from the Eclipse Marketplace.)
But the "Build Output Parser" still does not provide any output. As I mentioned above, the include paths start with -v and the defines with -d:
As I am quite new to Eclipse (or incapable of searching) - how/where did you gather the information that the XLC parser would help me out? Even though I got your hint, I was not able to find any information on it using a standard search procedure.
Maybe this is why I also failed to find the right information, which would help me out with the output parser...
Re: Juno CDT discovery not working [message #898482 is a reply to message #898319] Thu, 26 July 2012 08:59 Go to previous messageGo to next message
Anyway, I'm running a tool up front the xcc call, which basically receives the same input paths and defines but with "-I" and "-D" respectively. Putting that command as the "Compiler command pattern" for the "XLC Build Output Parser" works to some degree.
When building libraries, the same project/file is compiled with different definitions of a define in one build run (e.g. First with -DDISPLAY_TYPE=A, then with -DDISPLAY_TYPE=B). However in the project's entry list as well as in the file's entry list, only the defines of the last build seem to be listed.
First I had the container selected as project, but changed to file later on, when I discovered that some defines were only given for files in a certain make file.
And another question I have: In case a define of the compiler builtin defines is redefined in the make environment and passed to the compiler, the discovery lists both (obviously) in their according locations. Does the discovery then use the one of the build output?
Re: Juno CDT discovery not working [message #898597 is a reply to message #898482] Thu, 26 July 2012 15:13 Go to previous messageGo to next message
Indexer will use macro definitions in the order they are shown in "Entries" tab, i.e. it will look first at "User Settings Entries" and then at the other providers in order. You can change the order in "Providers" tab.
Re: Juno CDT discovery not working [message #898701 is a reply to message #898597] Fri, 27 July 2012 05:19 Go to previous messageGo to next message
Does use in order mean takes first it finds or last one wins?
And sorry, my example was wrong - of course the latter definition would be taken.
But the example is actually this:
For the first library, -DDISPLAY_TYPE_A= is passed and for the second one -DDISPLAY_TYPE_B= is passed.
So I would expect to find both defines in the discovered output list, since it's the same build, or what am I missing?
Re: Juno CDT discovery not working [message #899008 is a reply to message #898701] Mon, 30 July 2012 03:10 Go to previous message
Just for the record: First one found wins.
Previous Topic:C++ option in Preferences is missing
Next Topic:Unresolved symbol yet again but in a new flavour (Juno)
Current Time: Sat Jul 19 20:53:54 EDT 2025
Powered by FUDForum. Page generated in 0.05568 seconds
