Home » Modeling » EMF » [xcore] Code Snippet ignored with derived and refers references(The xcore get snippet is not propagated into the generated classes when using refers.)
[xcore] Code Snippet ignored with derived and refers references [message #896746] Thu, 19 July 2012 10:57 Go to next message
Hi Ed,
I really like the new way to create meta-model. So far, it is going well. Just a little question. I have the following model
class EVariable extends ENamedElement{
container EVariables eVariables opposite eVariables
refers EClass eClass
@GenModel(children="false", property="Readonly")
refers readonly volatile transient derived EProgram eProgram get{
if (EVariables == null) return null else return EVariables.EProgram
The code generated is the following:
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
public EProgram getEProgram()
EProgram eProgram = basicGetEProgram();
return eProgram != null && eProgram.eIsProxy() ? (EProgram)eResolveProxy((InternalEObject)eProgram) : eProgram;
* @generated
public EProgram basicGetEProgram()
// TODO: implement this method to return the 'EProgram' reference
// -> do not perform proxy resolution
// Ensure that you remove @generated or mark it @generated NOT
throw new UnsupportedOperationException();
Is it normal? I tested with contains instead of refers and the snippet is generated properly. In my case, it is really a weak container.
Re: [xcore] Code Snippet ignored with derived and refers references [message #896845 is a reply to message #896746] Fri, 20 July 2012 02:36 Go to previous messageGo to next message
Comments below.
On 19/07/2012 4:57 PM, Régent L Archevêque wrote:
> Hi Ed,
It's a look more awesome. :-P
> following model
Usually I don't like pluralized names for classes. It makes it hard to
write well formed English sentences with the. E.g., "I used the
generated factory to create an EVariables."
It seemed so common for a derived feature to be readonly, transient, and
volatile that this is implied by "derived". We'll need to look at
keyword to specify otherwise.
You should be able to use EVariables?.EProgram. (I'm not so happy with
Xbase's initial upper case letter here.)
> * @generated
I would have expected the body you specified. Please open a bugzilla.
I'll address this in the maintenance stream. We've just set up builds
for that so builds will be available soon.
> * @generated
If you added the keyword "local" before or right after the "refers" to
specify that this feature isn't proxy resolving, you shouldn't get this
method. I tested and it actually solves the problem above as well. I
suppose to be fully general we'd have to allow you to specify the logic
for this as well.
> Is it normal?
No.
I expect container is handled a bit differently (wrongly in this case)
because it essence it's always a derived feature, i.e., derived for
EObject.eContainer(). And in fact, I think the logic you're specifying
for this produces an inconsistency because I assume you have something
like this:
package org.example.foo
import org.eclipse.emf.ecore.ENamedElement
import org.eclipse.emf.ecore.EClass
local refers readonly volatile transient derived EProgram eProgram get{
class EProgram
contains EVariables eVariables opposite eProgram
class EVariables
container EProgram eProgram opposite eVariables
contains EVariable eVariables opposite eVariables
I.e., the container for the variable is really an (sic) EVariables, not
an EProgram. So I really don't think you should be specifying a
derived container as you have. You should define a derived reference...
And you shouldn't be extending Ecore!!!
> Thanks
Re: [xcore] Code Snippet ignored with derived and refers references [message #896987 is a reply to message #896845] Fri, 20 July 2012 12:45 Go to previous messageGo to next message
Thanks for your explanations. I'll raise a bug report about the code snippet not generated.
Re: [xcore] Code Snippet ignored with derived and refers references [message #897025 is a reply to message #896987] Fri, 20 July 2012 15:41 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Régent,<br>
<br>
Please consider carefully my comment about the fact that you're
defining a container reference that is <b>not  </b>properly a
container reference.  It's not properly the opposite of the
containment reference.  I.e., the object will not be among the
container's eContents() and that container's  eContainmentFeature()
will not return the expected container reference.  What you're
defining is simply a derived reference.<br>
<br>
<div class="moz-cite-prefix">On 20/07/2012 6:45 PM, Régent L
Archevêque wrote:<br>
</div>
<blockquote cite="mid:juc1vu$351$1@xxxxxxxxe.org" type="cite">Thanks
<br>
</blockquote>
<br>
</body>
</html>
Re: [xcore] Code Snippet ignored with derived and refers references [message #897238 is a reply to message #897025] Mon, 23 July 2012 07:09 Go to previous message
Copy Wink
Previous Topic:Use EObjectValidator in UpdateValueStrategy
Next Topic:Problem accessing resources in other depending projects
Current Time: Sun Jul 20 14:03:42 EDT 2025
Powered by FUDForum. Page generated in 0.38960 seconds
