Home » Newcomers » Newcomers » AspectJ 1.7 compatibility with JDK1.6(Is AspectJ1.7 version is supported in JDK 1.6)
AspectJ 1.7 compatibility with JDK1.6 [message #896841] Fri, 20 July 2012 02:09 Go to next message
Hi All,
I am new to AspectJ and I am using AspectJ1.7 version.
I have some queries regarding version compatibility.
Does AspectJ1.7 is compatible with JDK 1.6? Does AspectJ 1.7 compilers and weavers need JDK 1.7 version or it is supported in JDK1.6 itself.
And the other thing is what new features of AspectJ 1.7 is applicable in JDK 1.6 version.
Jeevitha
Re: AspectJ 1.7 compatibility with JDK1.6 [message #897183 is a reply to message #896841] Sun, 22 July 2012 22:52 Go to previous messageGo to next message
Yep. You can use JDK 1.6 with aspectj 1.7. You must set your source and target levels appropriately in order to do this. For example, in Eclipse, you must set your Java compiler compliance level (Perferences -> Java -> Compiler -> JDK Compliance) to 1.6. In this case, however, 1.7 language features will be disabled.
There are quite a few bug fixes and a few smaller features. Check out the readme for the 1.7 release.
http://eclipse.org/aspectj/doc/released/README-170.html
And the best place to ask questions about aspectj is the mailing list.
http://eclipse.org/aspectj/userlists.php
Re: AspectJ 1.7 compatibility with JDK1.6 [message #897195 is a reply to message #897183] Mon, 23 July 2012 02:30 Go to previous messageGo to next message
Thanks Andrew!!
Bytecode Caching in AspectJ [message #897206 is a reply to message #897195] Mon, 23 July 2012 03:46 Go to previous messageGo to next message
Hi Andrew!!
May I know what is Bytecode Caching in AspectJ1.7?
And when caching is enabled, what exactly is cached??
What is the life of Caching? Is it automatically refreshed or is Static?
Is there any Memory limit for Caching? ie. If only to certain extent Caching is done or is unlimited??
Jeevitha
Re: Bytecode Caching in AspectJ [message #897327 is a reply to message #897206] Mon, 23 July 2012 11:24 Go to previous messageGo to next message
Bytecode caching allows the loadtime weaver to weave the bytecode once and then cache the results so that loadtime weaving starts much faster.
I can't tell you much more than that. I'd recommend that you send a message to the aspectj users mailing list, over here:
http://dev.eclipse.org/mailman/listinfo/aspectj-dev
Re: Bytecode Caching in AspectJ [message #898256 is a reply to message #897327] Thu, 26 July 2012 01:18 Go to previous messageGo to next message
Hi Andrew,
I have posted Aspectj related queries to aspectj users mailing list but I didn't receive any reply.
So, please can you help me in this regard.
Re: Bytecode Caching in AspectJ [message #898576 is a reply to message #898256] Thu, 26 July 2012 11:57 Go to previous messageGo to next message
Andy, the one who implemented the caching is currently on vacation (will return Friday). He should be able to answer then.
Re: Bytecode Caching in AspectJ [message #898674 is a reply to message #898576] Fri, 27 July 2012 03:04 Go to previous message
Thanks Andrew!!!
Previous Topic:application "com.yocos.bootstrap.application" could not be found in the registry
Next Topic:eclipse.cdt
Current Time: Sat Jul 19 05:04:47 EDT 2025
Powered by FUDForum. Page generated in 0.09426 seconds
