Home » Modeling » EMF » [Xcore] Imposing constraints on Xcore model
[Xcore] Imposing constraints on Xcore model [message #896657] |
Thu, 19 July 2012 06:02  |
I'm working with Xcore to develop a model.
Now, I want to impose constraints on that model. I used to do it with OCL in Xtext (in the ecore file). Is it possible to implement constraints in an Xcore model? It doesn't have to be OCL.
Any help or clues are welcome.
Thanks for your time.
Re: [Xcore] Imposing constraints on Xcore model [message #896702 is a reply to message #896695] |
Thu, 19 July 2012 08:18   |
Wouter,
If you have an existing *.genmodel, you can export the model to Xcore
(as described in the wiki). Below is Ecore.genmodel exported to Xcore.
Note the @Ecore(constraints="...") declarations.
@Ecore(nsURI="http://www.eclipse.org/emf/2002/Ecore")
@GenModel(modelDirectory="/org.eclipse.emf.ecore/src",
runtimeJar="true", updateClasspath="false", booleanFlagsField="eFlags",
booleanFlagsReservedBits="8",
importerID="org.eclipse.emf.importer.ecore", containmentProxies="true",
minimalReflectiveMethods="false",
language="en")
package org.eclipse.emf.ecore
@Ecore(constraints="ConsistentTransient")
class EAttribute extends EStructuralFeature
EBoolean iD
refers readonly transient volatile derived EDataType [1] eAttributeType
@Ecore(constraints="WellFormedSourceURI")
class EAnnotation extends EModelElement
EString source
contains EStringToStringMapEntry [] details
container transient EModelElement eModelElement opposite eAnnotations
contains EObject [] contents
refers EObject [] references
@Ecore(constraints="InterfaceIsAbstract AtMostOneID UniqueFeatureNames
UniqueOperationSignatures NoCircularSuperTypes WellFormedMapEntryClass
ConsistentSuperTypes DisjointFeatureAndOperationSignatures")
class EClass extends EClassifier
EBoolean ^abstract
EBoolean ^interface
@GenModel(suppressedIsSetVisibility="true",
suppressedUnsetVisibility="true")
refers unsettable EClass [] eSuperTypes
contains EOperation [] eOperations opposite eContainingClass
refers readonly transient volatile derived EAttribute [] eAllAttributes
refers readonly transient volatile derived EReference [] eAllReferences
refers readonly transient volatile derived EReference [] eReferences
refers readonly transient volatile derived EAttribute [] eAttributes
eAllContainments
refers readonly transient volatile derived EOperation [] eAllOperations
refers readonly transient volatile derived EStructuralFeature []
eAllStructuralFeatures
refers readonly transient volatile derived EClass [] eAllSuperTypes
refers local readonly transient volatile derived EAttribute
eIDAttribute
contains EStructuralFeature [] eStructuralFeatures opposite
eContainingClass
contains unsettable EGenericType [] eGenericSuperTypes
refers readonly transient volatile derived EGenericType []
eAllGenericSuperTypes
op EBoolean isSuperTypeOf(EClass someClass)
op EInt getFeatureCount()
op EStructuralFeature getEStructuralFeature(EInt featureID)
op EInt getFeatureID(EStructuralFeature feature)
op EStructuralFeature getEStructuralFeature(EString featureName)
op EInt getOperationCount()
op EOperation getEOperation(EInt operationID)
op EInt getOperationID(EOperation operation)
op EOperation getOverride(EOperation operation)
@Ecore(constraints="WellFormedInstanceTypeName UniqueTypeParameterNames")
abstract class EClassifier extends ENamedElement
volatile unsettable EString instanceClassName
readonly transient volatile derived EJavaClass<?> instanceClass
readonly transient volatile derived EJavaObject defaultValue
volatile unsettable EString instanceTypeName
container resolving readonly transient EPackage ePackage opposite
eClassifiers
contains resolving ETypeParameter [] eTypeParameters
op EBoolean isInstance(EJavaObject object)
op EInt getClassifierID()
class EDataType extends EClassifier
EBoolean serializable = "true"
@Ecore(constraints="UniqueEnumeratorNames UniqueEnumeratorLiterals")
class EEnum extends EDataType
contains EEnumLiteral [] eLiterals opposite eEnum
op EEnumLiteral getEEnumLiteral(EString name)
op EEnumLiteral getEEnumLiteral(EInt value)
op EEnumLiteral getEEnumLiteralByLiteral(EString literal)
class EEnumLiteral extends ENamedElement
EInt value
transient EEnumerator instance
EString literal
container readonly transient EEnum eEnum opposite eLiterals
class EFactory extends EModelElement
refers local transient EPackage [1] ePackage opposite eFactoryInstance
op EObject ^create(EClass eClass)
op EJavaObject createFromString(EDataType eDataType, EString
literalValue)
op EString convertToString(EDataType eDataType, EJavaObject
instanceValue)
abstract class EModelElement
contains EAnnotation [] eAnnotations opposite eModelElement
op EAnnotation getEAnnotation(EString source)
@Ecore(constraints="WellFormedName")
abstract class ENamedElement extends EModelElement
EString name
class EObject
op EClass eClass()
op EBoolean eIsProxy()
op EResource eResource()
op EObject eContainer()
op EStructuralFeature eContainingFeature()
op EReference eContainmentFeature()
op EEList<EObject> eContents()
op ETreeIterator<EObject> eAllContents()
op EEList<EObject> eCrossReferences()
op EJavaObject eGet(EStructuralFeature feature)
op EJavaObject eGet(EStructuralFeature feature, EBoolean resolve)
op void eSet(EStructuralFeature feature, EJavaObject newValue)
op EBoolean eIsSet(EStructuralFeature feature)
op void eUnset(EStructuralFeature feature)
op EJavaObject eInvoke(EOperation operation, EEList<?> arguments)
throws EInvocationTargetException
@Ecore(constraints="UniqueParameterNames UniqueTypeParameterNames
NoRepeatingVoid")
class EOperation extends ETypedElement
container readonly transient EClass eContainingClass opposite
eOperations
contains EParameter [] eParameters opposite eOperation
refers unsettable EClassifier [] eExceptions
contains unsettable EGenericType [] eGenericExceptions
op EInt getOperationID()
op EBoolean isOverrideOf(EOperation someOperation)
@Ecore(constraints="WellFormedNsURI WellFormedNsPrefix
UniqueSubpackageNames UniqueClassifierNames UniqueNsURIs")
class EPackage extends ENamedElement
EString nsURI
EString nsPrefix
refers local transient EFactory [1] eFactoryInstance opposite ePackage
contains resolving EClassifier [] eClassifiers opposite ePackage
contains resolving EPackage [] eSubpackages opposite eSuperPackage
container resolving readonly transient EPackage eSuperPackage
opposite eSubpackages
op EClassifier getEClassifier(EString name)
class EParameter extends ETypedElement
container readonly transient EOperation eOperation opposite eParameters
@Ecore(constraints="ConsistentOpposite SingleContainer ConsistentKeys
ConsistentUnique ConsistentContainer")
class EReference extends EStructuralFeature
EBoolean containment
readonly transient volatile derived EBoolean ^container
EBoolean resolveProxies = "true"
refers EReference eOpposite
refers readonly transient volatile derived EClass [1] eReferenceType
refers EAttribute [] eKeys
@Ecore(constraints="ValidDefaultValueLiteral")
abstract class EStructuralFeature extends ETypedElement
EBoolean changeable = "true"
EBoolean ^volatile
EBoolean ^transient
EString defaultValueLiteral
EBoolean ^unsettable
EBoolean ^derived
eStructuralFeatures
op EInt getFeatureID()
op EJavaClass<?> getContainerClass()
@Ecore(constraints="ValidLowerBound ValidUpperBound ConsistentBounds
ValidType")
abstract class ETypedElement extends ENamedElement
EBoolean ordered = "true"
EBoolean ^unique = "true"
EInt lowerBound
EInt upperBound = "1"
readonly transient volatile derived EBoolean many
readonly transient volatile derived EBoolean required
refers volatile unsettable EClassifier eType
contains volatile unsettable EGenericType eGenericType
@ExtendedMetaData(baseType="http://www.w3.org/2001/XMLSchema#decimal")
type EBigDecimal wraps java.math.BigDecimal
@ExtendedMetaData(baseType="http://www.w3.org/2001/XMLSchema#integer")
type EBigInteger wraps java.math.BigInteger
@ExtendedMetaData(baseType="http://www.w3.org/2001/XMLSchema#boolean")
type EBoolean wraps boolean
@ExtendedMetaData(baseType="EBoolean", name="EBoolean:Object")
type EBooleanObject wraps Boolean
@ExtendedMetaData(baseType="http://www.w3.org/2001/XMLSchema#byte")
type EByte wraps byte
@ExtendedMetaData(baseType="http://www.w3.org/2001/XMLSchema#hexBinary")
type EByteArray wraps byte [ ]
@ExtendedMetaData(baseType="EByte", name="EByte:Object")
type EByteObject wraps Byte
type EChar wraps char @ExtendedMetaData(baseType="EChar",
name="EChar:Object")
type ECharacterObject wraps Character
type EDate wraps java.util.Date
type EDiagnosticChain wraps org.eclipse.emf.common.util.DiagnosticChain
@ExtendedMetaData(baseType="http://www.w3.org/2001/XMLSchema#double")
type EDouble wraps double @ExtendedMetaData(baseType="EDouble",
name="EDouble:Object")
type EDoubleObject wraps Double
type EEList < E > wraps org.eclipse.emf.common.util.EList
type EEnumerator wraps org.eclipse.emf.common.util.Enumerator
type EFeatureMap wraps util.FeatureMap
type EFeatureMapEntry wraps util.FeatureMap$Entry
@ExtendedMetaData(baseType="http://www.w3.org/2001/XMLSchema#float")
type EFloat wraps float @ExtendedMetaData(baseType="EFloat",
name="EFloat:Object")
type EFloatObject wraps Float
@ExtendedMetaData(baseType="http://www.w3.org/2001/XMLSchema#int")
type EInt wraps int @ExtendedMetaData(baseType="EInt", name="EInt:Object")
type EIntegerObject wraps Integer
type EJavaClass < T > wraps Class
type EJavaObject wraps Object
@ExtendedMetaData(baseType="http://www.w3.org/2001/XMLSchema#long")
type ELong wraps long @ExtendedMetaData(baseType="ELong",
name="ELong:Object")
type ELongObject wraps Long
type EMap < K , V > wraps java.util.Map
type EResource wraps resource.Resource
type EResourceSet wraps resource.ResourceSet
@ExtendedMetaData(baseType="http://www.w3.org/2001/XMLSchema#short")
type EShort wraps short @ExtendedMetaData(baseType="EShort",
name="EShort:Object")
type EShortObject wraps Short
@ExtendedMetaData(baseType="http://www.w3.org/2001/XMLSchema#string")
type EString wraps String
class EStringToStringMapEntry wraps java.util.Map$Entry
EString key
EString value
type ETreeIterator < E > wraps org.eclipse.emf.common.util.TreeIterator
@Ecore(constraints="ConsistentType ConsistentBounds ConsistentArguments")
class EGenericType
contains EGenericType eUpperBound
contains EGenericType [] eTypeArguments
refers readonly transient derived EClassifier [1] eRawType
contains EGenericType eLowerBound
refers local ETypeParameter eTypeParameter
refers EClassifier eClassifier
class ETypeParameter extends ENamedElement
contains EGenericType [] eBounds
type EInvocationTargetException wraps reflect.InvocationTargetException
On 19/07/2012 2:05 PM, Wouter Schaekers wrote:
> Ed Merks wrote on Thu, 19 July 2012 06:58
>> Wouter,
>> Sorry, Xcore doesn't currently support specifying the behavior of
>> constraints. You can declare them with @Ecore annotations, but
>> that's it. Hopefully during the Kepler release cycle I can find time
>> to add that.
> Thanks for your answer.
> Can you give a simple example? That would help a lot.
Re: [Xcore] Imposing constraints on Xcore model [message #901189 is a reply to message #901182] |
Fri, 10 August 2012 05:01   |
Christoph,
Comments below.
On 10/08/2012 10:41 AM, Christoph Keimel wrote:
> Hi
> I have started working with xcore and love it! Right now I am facing
> the same situation, as the original poster: I want to add constraints
> and/or invariants to the model.
> Both approaches have the excpected result:
> @Ecore(constraints="foo")
> class Bar {
> } and
> class Bar {
> op boolean hasFoo(EDiagnosticChain diagnostics, EMap<Object, Object>
> context)
For the invariant you can specify the actual body...
> The corresponding methods in Bar and *Validator are created. The only
> draw back is, that these methods need to be manualy changed and will
> therefore be overwritten by a project "clean".
That's true for the constraint, but for the invariant you can specify
the body, right? If you avoid generating into the src-gen folder (the
folder specified in the Xcore compiler options), it won't get cleaned.
You can specify the model directory with an @GenModel annotation.
> Are there any best practices on working with these situations. Are
> there any current developments that might help?
Hopefully I'll have time to get constraints working nicely for Kepler...
> Greetings
> Christoph
Re: [Xcore] Imposing constraints on Xcore model [message #901222 is a reply to message #901216] |
Fri, 10 August 2012 08:13   |
Christoph,
Comments below.
On 10/08/2012 1:36 PM, Christoph Keimel wrote:
> Hi Ed,
> thanks for the reply.
> [quote title=Ed Merks wrote on Fri, 10 August 2012 11:01]
>> the body, right?
> Yes, but you also need to include the stuff that is normaly generated.
> I got stuck with that experiment on the array definition. See my later
> post:
> http://www.eclipse.org/forums/index.php/mv/msg/367759/901193/#msg_901193
I'll look...
>> If you avoid generating into the src-gen folder (the folder specified
>> in the Xcore compiler options), it won't get cleaned. You can
> Good tip. Thanks.
> Is there a bug where you are tracking the development in this area?
No, feel free to open one for tracking purposes.
> Greetings
> Christoph
Re: [Xcore] Imposing constraints on Xcore model [message #901225 is a reply to message #901193] |
Fri, 10 August 2012 08:17   |
Christoph,
This approach looks good. I'm not sure the Xbase syntax for an array
literal or if it even has one. In the worst case, I guess you can
create an array of the right size and assign the elements.
I'd suggest asking on eclipse.tmf with a subject starting with [xbase]
what the recommended equivalent of Java's "new Object [] { value }" is
in Xbase.
On 10/08/2012 11:10 AM, Christoph Keimel wrote:
> Experimenting further ... this approach seems to be a good start:
> (The goal of this experiment is to introduce an invariant on the
> attribute name which can not be null or an empty string.)
> class CompanyElement {
> String name
> op boolean hasName(EDiagnosticChain diagnostics, EMap<Object,
> Object> context) {
> if (name == null || name == "") {
> if (diagnostics != null) {
> diagnostics.add(new BasicDiagnostic(Diagnostic::ERROR,
> CompanyValidator::DIAGNOSTIC_SOURCE,
> CompanyValidator::COMPANY_ELEMENT__HAS_NAME,
> "The Name can not be empty",
> null))
> } else true
> The "null" as last parameter to BasicDiagnostics is wrong of course. I
> couldn't figure out how to write "new Object [] { this }" in xcore.
> Any pointers on this?
> What do you think about this approach?
> Greetings
> Christoph
Re: [Xcore] Imposing constraints on Xcore model [message #901436 is a reply to message #901241] |
Sun, 12 August 2012 06:48  |
In case anybody needs this: After some help from Christian Dietrich (thanks!) I came up with the following transfer of the generated validation code to xcore:
package de.emsw.model.company
import org.eclipse.emf.common.util.BasicDiagnostic
import org.eclipse.emf.common.util.Diagnostic
import org.eclipse.emf.ecore.EDiagnosticChain
import org.eclipse.emf.ecore.EMap
import org.eclipse.emf.ecore.plugin.EcorePlugin
import org.eclipse.emf.ecore.util.EObjectValidator
String name
op boolean hasName(EDiagnosticChain diagnostics, EMap<Object, Object> context) {
"de.emsw.model.company", //CompanyValidator::DIAGNOSTIC_SOURCE,
0, //CompanyValidator::COMPANY_ELEMENT__HAS_NAME,
EcorePlugin::INSTANCE.getString("_UI_GenericInvariant_diagnostic", <Object>newArrayList("hasName", EObjectValidator::getObjectLabel(this, context))),
<Object>newArrayList(this)))
} else true
The part including the block "if (diagnostics != null)" is normally generated by ecore when an invariant is recognised.
Lines 16 and 17 are hard coded here, because CompanyValidator only exists after the build and not before leading to a build dead lock. See: Bug 387015
Current Time: Sat Jul 19 23:46:32 EDT 2025
Powered by FUDForum. Page generated in 0.05327 seconds
