[xcore] problem referencing UML classes? [message #896679] |
Thu, 19 July 2012 07:10  |
I have a problem referencing UML classes in my XCore model.
Consider the following example:
package org.example.myumlapplication
import org.eclipse.uml2.uml.Lifeline
class MyClass{
refers Lifeline lifeline
The import works fine, but when I add the reference, there are two NullPointerExceptions (see below).
(I'm using an e4 Modeling Tools installation, i.e., UML is installed as deployed plug-ins)
Is there a general problem referencing UML, or am I doing something wrong?
Joel
1. An internal error occurred during: "Xtext validation".
at org.eclipse.emf.ecore.xcore.util.XcoreGenModelBuilder.initializeUsedGenPackages(XcoreGenModelBuilder.java:268)
at org.eclipse.emf.ecore.xcore.resource.XcoreModelAssociator.installDerivedState(XcoreModelAssociator.java:82)
at org.eclipse.xtext.resource.DerivedStateAwareResource.installDerivedState(DerivedStateAwareResource.java:125)
at org.eclipse.xtext.resource.DerivedStateAwareResource.getContents(DerivedStateAwareResource.java:48)
at org.eclipse.emf.ecore.util.EcoreUtil.getAllContents(EcoreUtil.java:1121)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.resolveLazyCrossReferences(LazyLinkingResource.java:97)
at org.eclipse.xtext.EcoreUtil2.resolveLazyCrossReferences(EcoreUtil2.java:494)
at org.eclipse.xtext.validation.ResourceValidatorImpl.resolveProxies(ResourceValidatorImpl.java:127)
at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:62)
at org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec(ValidationJob.java:79)
at org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec(ValidationJob.java:1)
at org.eclipse.xtext.util.concurrent.AbstractReadWriteAcces.readOnly(AbstractReadWriteAcces.java:32)
at org.eclipse.xtext.ui.editor.model.XtextDocument.readOnly(XtextDocument.java:78)
at org.eclipse.xtext.ui.editor.validation.ValidationJob.createIssues(ValidationJob.java:75)
at org.eclipse.xtext.ui.editor.validation.ValidationJob.run(ValidationJob.java:64)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
2. An internal error occurred during: "XtextReconcilerJob".
at org.eclipse.emf.ecore.resource.impl.ResourceImpl$4.getChildren(ResourceImpl.java:519)
at org.eclipse.emf.common.util.AbstractTreeIterator.hasAnyChildren(AbstractTreeIterator.java:97)
at org.eclipse.emf.common.util.AbstractTreeIterator.hasNext(AbstractTreeIterator.java:85)
at org.eclipse.xtext.xbase.ui.highlighting.XbaseHighlightingCalculator.searchAndHighlightElements(XbaseHighlightingCalculator.java:120)
at org.eclipse.xtext.xbase.ui.highlighting.XbaseHighlightingCalculator.doProvideHighlightingFor(XbaseHighlightingCalculator.java:115)
at org.eclipse.xtext.xbase.ui.highlighting.XbaseHighlightingCalculator.provideHighlightingFor(XbaseHighlightingCalculator.java:92)
at org.eclipse.xtext.ui.editor.syntaxcoloring.MergingHighlightedPositionAcceptor.provideHighlightingFor(MergingHighlightedPositionAcceptor.java:51)
at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingReconciler.reconcilePositions(HighlightingReconciler.java:88)
at org.eclipse.xtext.ui.editor.syntaxcoloring.HighlightingReconciler.modelChanged(HighlightingReconciler.java:281)
at org.eclipse.xtext.ui.editor.model.XtextDocument.notifyModelListeners(XtextDocument.java:118)
at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.afterModify(XtextDocument.java:172)
at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.afterModify(XtextDocument.java:1)
at org.eclipse.xtext.util.concurrent.AbstractReadWriteAcces.modify(AbstractReadWriteAcces.java:50)
at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.modify(XtextDocument.java:181)
at org.eclipse.xtext.ui.editor.model.XtextDocument.internalModify(XtextDocument.java:90)
at org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy.reconcile(XtextDocumentReconcileStrategy.java:44)
at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler.run(XtextReconciler.java:254)
Re: [xcore] problem referencing UML classes? [message #896696 is a reply to message #896684] |
Thu, 19 July 2012 08:03   |
Mmh, this UML genmodel is causing problems all the time... :(
On 19.07.2012 13:32, Ed Merks wrote:
> Joel,
> This problem is caused by UML2's GenModel's specialized handling (like a built-in package) for their new (for the Juno release) Types package.:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=382637
> On 19/07/2012 1:10 PM, Joel Greenyer wrote:
>> Hi,
>> class MyClass{
>> Joel
>> java.lang.NullPointerException
Re: [xcore] problem referencing UML classes? [message #896697 is a reply to message #896696] |
Thu, 19 July 2012 08:05  |
Joel,
Yes, it's basically broken in terms of being able to use it with any
other GenModels. :-( Hopefully Kenn can fix it in the maintenance stream.
>> Joel,
>> package.:
>>> Hi,
>>> class MyClass{
>>> wrong?
>>> Joel
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
FUDForum. Page generated in 0.05347 seconds
