Creating a project that supply common terminals? [message #894765] |
Tue, 10 July 2012 08:46  |
Hi, I would like to create a common project where I can put common terminals and maybe some data types.
I think that this kind of project should be simple and don't need any UI project.
So, what fragments could I safely remove from the generated .mwe2 file ?
*update:
I've got this error in my project that only contains terminals and one data type:
6171 [main] ERROR enerator.CompositeGeneratorFragment - You may not generate an ANTLR parser for a grammar without production rules.
java.lang.IllegalArgumentException: You may not generate an ANTLR parser for a grammar without production rules.
at org.eclipse.xtext.generator.parser.antlr.AbstractAntlrGeneratorFragment.generate(AbstractAntlrGeneratorFragment.java:89)
at org.eclipse.xtext.generator.parser.antlr.XtextAntlrGeneratorFragment.generate(XtextAntlrGeneratorFragment.java:41)
at org.eclipse.xtext.generator.CompositeGeneratorFragment.generate(CompositeGeneratorFragment.java:92)
at org.eclipse.xtext.generator.LanguageConfig.generate(LanguageConfig.java:113)
at org.eclipse.xtext.generator.Generator.generate(Generator.java:361)
at org.eclipse.xtext.generator.Generator.invokeInternal(Generator.java:128)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:126)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:34)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:201)
at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.invoke(AbstractCompositeWorkflowComponent.java:35)
at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:19)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:102)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
thanks,
Cristiano
[Updated on: Tue, 10 July 2012 09:06] by Moderator
Re: Creating a project that supply common terminals? [message #896449 is a reply to message #894765] |
Wed, 18 July 2012 08:17  |
I'd expect you don't need to generate anything for that grammar. Maybe
the Ecore stuff, if you want common datatypes. But that can also be
maintained manually, and you might have to manually implement value
converters anyway.
For our similar grammars 'Terminals' and 'Xtype', we don't generate
anything.
Am 10.07.12 14:46, schrieb Cristiano Gaviao:
> project.
> thanks,
> Cristiano
FUDForum. Page generated in 0.06747 seconds
