Home » Modeling » EMF » [xcore] refering to classes in non XCore ecore models
[xcore] refering to classes in non XCore ecore models [message #895988] Mon, 16 July 2012 14:24 Go to next message
in an XCore model/plug-in I'm trying to refer to another EClass modeled in a regular .ecore file in another plugin.
The former plug-in depends on the latter, the import seems to work, but in the line "refers" (see example below), it says
"Multiple markers at this line - A generic type in this context must refer to a classifier or a type parameter -
Couldn't resolve reference to GenBase 'Blub'."
------Example------
package org.example.coolpackage
import org.example.anothercoolpackage.Blub
class Bla{
refers Blub b
------EndExample------
Am I missing a reference to the ecore model / it's genmodel?
Thanks for helping
Joel
Re: [xcore] refering to classes in non XCore ecore models [message #896052 is a reply to message #895988] Tue, 17 July 2012 01:28 Go to previous messageGo to next message
Joel,
Comments below.
On 16/07/2012 8:24 PM, Joel Greenyer wrote:
> ------Example------
> class Bla{
> refers Blub b
The other model's project must have an Xtext nature
(File->Configure->Add Xtext nature) in order for Xtext's indexing
infrastructure to index it and that's needed in order for Xcore to know
about the indexed *.genmodel resources in that project. Failing that,
the *.genmodel resources need to be on the classpath, which is the case
only when a bundle is properly deployed as runtime bundle to include the
model folder in the bundle and where the classes are in "." rather than
"bin" as they are at development time. It's an annoying and long
standing issue that the PDE doesn't put everything that's on the actual
runtime path after deployment on the classpath at development time...
> Thanks for helping
> Joel
Re: [xcore] refering to classes in non XCore ecore models [message #896068 is a reply to message #896052] Tue, 17 July 2012 03:07 Go to previous messageGo to next message
Hi Ed,
Works. Thanks for the explanation.
Maybe you should add this to your XCore wiki article... I'm sure others will come across this.
Ciao
Joel
On 17.07.2012 07:28, Ed Merks wrote:
> Joel,
> Comments below.
>> Hi,
>> ------Example------
>> class Bla{
>> refers Blub b
> The other model's project must have an Xtext nature (File->Configure->Add Xtext nature) in order for Xtext's indexing infrastructure to index it and that's needed in order for Xcore to know about the indexed *.genmodel resources in that project. Failing that, the *.genmodel resources need to be on the classpath, which is the case only when a bundle is properly deployed as runtime bundle to include the model folder in the bundle and where the classes are in "." rather than "bin" as they are at development time. It's an annoying and long standing issue that the PDE doesn't put everything that's on the actual runtime path after deployment on the classpath at development time...
>> Thanks for helping
>> Joel
Re: [xcore] refering to classes in non XCore ecore models [message #896219 is a reply to message #896068] Tue, 17 July 2012 11:39 Go to previous messageGo to next message
I have another problem.
If I say
class Bla extends Blub{
I have the problem that in the generated Package class there is a line
int BLA_OPERATION_COUNT = AnothercoolpackagePackage.BLUB_OPERATION_COUNT + 0;
where "BLUB_OPERATION_COUNT cannot be resolved or is not a field", i.e., the ...__OPERATION_COUNT field is not generated for the class in the package generated from standard ecore-&genmodel.
Is there anything I can do about that?
Joel
On 17.07.2012 09:07, Joel Greenyer wrote:
> Hi Ed,
> Ciao
> Joel
>> Joel,
>> Comments below.
>>> Hi,
>>> ------Example------
>>> class Bla{
>>> refers Blub b
>>> Thanks for helping
>>> Joel
Re: [xcore] refering to classes in non XCore ecore models [message #896342 is a reply to message #896219] Wed, 18 July 2012 02:54 Go to previous messageGo to next message
Joel,
The base model must support Operation Reflection (it's false by default)
or the derived model must not (it's true by default for Xcore models).
As you probably know, you can use the properties view to set such things
for your Xcore model to produce the necessary @GenModel annotations.
On 17/07/2012 5:39 PM, Joel Greenyer wrote:
> If I say
> Thanks
> Joel
>> Hi Ed,
>> Ciao
>> Joel
>>> Joel,
>>> Comments below.
>>>> Hi,
>>>> ------Example------
>>>> class Bla{
>>>> refers Blub b
>>>> Thanks for helping
>>>> Joel
Re: [xcore] refering to classes in non XCore ecore models [message #896508 is a reply to message #896342] Wed, 18 July 2012 11:12 Go to previous messageGo to next message
great.
Thanks!
On 18.07.2012 08:54, Ed Merks wrote:
> Joel,
> The base model must support Operation Reflection (it's false by default) or the derived model must not (it's true by default for Xcore models). As you probably know, you can use the properties view to set such things for your Xcore model to produce the necessary @GenModel annotations.
>> Hi,
>> If I say
>> Thanks
>> Joel
>>> Hi Ed,
>>> Ciao
>>> Joel
>>>> Joel,
>>>> Comments below.
>>>>> Hi,
>>>>> ------Example------
>>>>> class Bla{
>>>>> refers Blub b
>>>>> Thanks for helping
>>>>> Joel
Re: [xcore] refering to classes in non XCore ecore models [message #898873 is a reply to message #895988] Sat, 28 July 2012 13:50 Go to previous messageGo to next message
I've got a similar problem extending TypesPackage::JvmIdentifiableElement.
The following xcore class is valid:
---- BEGIN XCORE EXAMPLE ----
class MyCustomJvmIdentifiableElement extends JvmIdenfiableElement {
String name
op String getIdentifier() {
name
op String getSimpleName() {
name
op String getQualifiedName() {
name
op String getQualifiedName(char separator) {
name
---- END XCORE EXAMPLE ----
But the generated Java function int eDerivedOperationID(int, Class<?>) contains errors: The int constants representing the super type's operations do not exist:
TypesPackage.JVM_IDENTIFIABLE_ELEMENT___GET_IDENTIFIER,
TypesPackage.JVM_IDENTIFIABLE_ELEMENT___GET_SIMPLE_NAME,
TypesPackage.JVM_IDENTIFIABLE_ELEMENT___GET_QUALIFIED_NAME,
TypesPackage.JVM_IDENTIFIABLE_ELEMENT___GET_QUALIFIED_NAME__CHAR
How to solve this error?
best regards,
Max
Re: [xcore] refering to classes in non XCore ecore models [message #898888 is a reply to message #898873] Sat, 28 July 2012 15:54 Go to previous messageGo to next message
Max,
At a glance, I suspect that the base model doesn't support reflective
operation invocation while your derived model, by default, does. Adding
@GenModel(operationReflection="false") on the package declaration should
avoid that.
On 28/07/2012 7:50 PM, Max Goltzsche wrote:
> Hello,
> String name
> name
> name
> name
> name
> best regards,
> Max
Re: [xcore] refering to classes in non XCore ecore models [message #898892 is a reply to message #898888] Sat, 28 July 2012 16:50 Go to previous message
Hello Ed,
thanks a lot. That was it. Sorry for asking the same question again but I thought I've tried this solution and it didn't work - well, it works very well!
best regards,
Max
Previous Topic:[TENEO] Inheritance Mapping Limitation
Next Topic:genmodel is not created because of missing type argument
Current Time: Sun Jul 20 07:44:12 EDT 2025
Powered by FUDForum. Page generated in 0.06221 seconds
