Home » Modeling » TMF (Xtext) » NPE opening external files
NPE opening external files [message #894553] Mon, 09 July 2012 11:07 Go to next message
I'm using xtext to develop an editor and during a test, I notice that if I try to open a file located outside eclipse workspace I get a NullPointer Exception:
	at org.eclipse.xtext.ui.editor.folding.DefaultFoldingStructureProvider.handleProjectionEnabled(DefaultFoldingStructureProvider.java:100)
	at org.eclipse.xtext.ui.editor.folding.DefaultFoldingStructureProvider$ProjectionChangeListener.projectionEnabled(DefaultFoldingStructureProvider.java:186)
	at org.eclipse.jface.text.source.projection.ProjectionViewer.fireProjectionEnabled(ProjectionViewer.java:487)
	at org.eclipse.jface.text.source.projection.ProjectionViewer.enableProjection(ProjectionViewer.java:535)
	at org.eclipse.jface.text.source.projection.ProjectionViewer.doOperation(ProjectionViewer.java:1414)
	at org.eclipse.xtext.ui.editor.XtextEditor.installFoldingSupport(XtextEditor.java:471)
	at org.eclipse.xtext.ui.editor.XtextEditor.createPartControl(XtextEditor.java:453)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:129)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:95)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:300)
This happens both if I use "File/open.." menu or if I "drag&drop" the file in the editor area.
I'm using eclipse 4.2 and I do not know if the problem is related to eclipse components or to xtext ones:
I tried to debug the problem and I saw that XtextDocumentProvider.setDocumentContent(IDocument document, IEditorInput editorInput, String encoding) asks super classes to set the content but both do not handle the provided FileStoreEditorInput (both super-classes come from eclipse.ui.editors)
thanks in advance for any hint/suggestion about how solve it
Nicola
ps. note, esternal files of "standard types" (like java, c and txt) are opened without any problem
Re: NPE opening external files [message #894559 is a reply to message #894553] Mon, 09 July 2012 11:20 Go to previous messageGo to next message
This is a known problem (don't have the bugzilla issue # for it).
Workarounds exist - I have one in cloudsmith/geppetto @ github where I
create a hidden "auto linked" project that automatically links to the
external files that are being opened. The problem is that resources
being edited must be Eclipse Resources as there is otherwise nothing to
tie things like markers and other meta data to.
The solution in Geppetto is not 100% generic, but should be easily
adapted to your dsl.
- henrik
The topic has been discussed in the forum a number of times.
On 2012-09-07 17:07, Nicola Serreli wrote:
> Hello,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Nicola
Re: NPE opening external files [message #894560 is a reply to message #894559] Mon, 09 July 2012 11:22 Go to previous messageGo to next message
This geppetto issue: https://github.com/cloudsmith/geppetto/issues/19
has links to more information, and shows what was changed in Geppetto to
allow editing of external files (i.e. the commit delta).
- henrik
> Regards
> - henrik
>> Hello,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Nicola
Re: NPE opening external files [message #894674 is a reply to message #894560] Tue, 10 July 2012 01:51 Go to previous messageGo to next message
Thanks for answers and links
Nicola
Re: NPE opening external files [message #894964 is a reply to message #894553] Wed, 11 July 2012 05:02 Go to previous messageGo to next message
Which version of Xtext do you use? This should be fixed in 2.3
Sebastian
Am 09.07.12 17:07, schrieb Nicola Serreli:
> Hello,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Nicola
Re: NPE opening external files [message #895030 is a reply to message #894964] Wed, 11 July 2012 08:59 Go to previous messageGo to next message
> Regards,
> Sebastian
Is there a description of how this was fixed somewhere? I am wondering
about if the fix in 2.3 allows editing, and in which context the file is
opened (i.e. what is visible to this file).
- henrik
Re: NPE opening external files [message #895898 is a reply to message #894964] Mon, 16 July 2012 09:05 Go to previous messageGo to next message
Sebastian Zarnekow wrote on Wed, 11 July 2012 05:02
Sebastian
Hi Sebastian,
you are right, with Xtext 2.3 I'm able to open external file, even in an empty workspace (no projects).
I just do a quick check and a lot of things are working:
- color and text format
- content assist
- the pop-up with the element documentation (with both mouse hover and content assist)
But there are (at least?) two problems:
- if I press "crtl-left click" on a reference, nothing happens, even if the referenced object is in the same file. Please note that the editor shows correctly the documentation associated to referenced object
- there is no validation while typing. If I ask (through pop-up menu) to force validation, I get NullPointerException:
	at org.eclipse.xtext.ui.editor.validation.AddMarkersOperation.execute(AddMarkersOperation.java:94)
	at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
	at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
	at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
	at org.eclipse.xtext.ui.editor.validation.MarkerIssueProcessor.processIssues(MarkerIssueProcessor.java:58)
	at org.eclipse.xtext.ui.editor.validation.ValidationJob.run(ValidationJob.java:67)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
clearly, I was not able to check if quick fix is working or not
Nicola
Re: NPE opening external files [message #896428 is a reply to message #895898] Wed, 18 July 2012 07:37 Go to previous message
Hi Nicola,
could you please file some tickets for your findings? That would be very
helpful.
Sebastian
Am 16.07.12 15:05, schrieb Nicola Serreli:
>> Regards,
>> Sebastian
> Hi Sebastian,
> - content assist
> content assist)
> at
> at
> at
> at
> at
> Regards,
> Nicola
Previous Topic:Server-side parsing concepts
Next Topic:Export DSL
Current Time: Sat Jul 19 19:41:23 EDT 2025
Powered by FUDForum. Page generated in 0.04552 seconds
