[CDO 4.1] : Reattachment issue with EOpposite [message #895893] |
Mon, 16 July 2012 08:43 |
Hi CDO Team,
We have a lock issue in one of our use cases, that I can explain using
the mode1.ecore example :
with 2 client sharing a model1.ecore based model with one Company owning
a Supplier and a PurchaseOrder, the Supplier referencing the PurchaseOrder,
The first client change the name of the Supplier and lock it (it doesn't
commit),
the second client clear the Company.purchaseOrders list and add yet the
PurchaseOrder then commit (theorically there is no change done by the
second client), the second client get the following exception on commit :
[ERROR] Rollback in MEMStore:
org.eclipse.net4j.util.concurrent.TimeoutRuntimeException: Could not
lock objects within 1000 milli seconds
at
org.eclipse.net4j.util.concurrent.RWOLockManager.wait(RWOLockManager.java:407)
at
org.eclipse.net4j.util.concurrent.RWOLockManager.lock2(RWOLockManager.java:89)
at
org.eclipse.emf.cdo.internal.server.TransactionCommitContext.lockObjects(TransactionCommitContext.java:804)
I have attached a JUnit test showing the issue, on the
Company.getPurchaseOrders().clear() I get a CDOSetFeatureDeltaImpl on
the opposite reference of PurchaseOrder (Supplier.purchaseOrders) and a
CDORemoveFeatureDeltaImpl on the Company.purchaseOrders reference.
On the company.getPurchaseOrders().add(purchaseOrder); I get a
CDOAddFeatureDeltaImpl on Company.purchaseOrders and a
CDOContainerFeatureDeltaImpl for the PurchaseOrder.eContainer java reference
Because of the ReattachTransition we shouldn't have changes before the
commit, right?
To explain our real use case, we use EMF Transaction with a pre-commit
(ResourceSetListenerImpl) to lock explicitly all changed objects, then
for client 1 we lock Supplier and for client 2 we lock the Company, but
like we have a Supplier as dirty objects on commit of client 2 we get
the previous exception.
It is a issue on the ReattachTransition or a bad use/understanding of CDO?
Best Regards.
FUDForum. Page generated in 0.03749 seconds
