TableLayout layouts too early [message #895804] |
Mon, 16 July 2012 02:28  |
I suspect that most users of TableLayout applied to an SWT Table that is
used as the main control of an Eclipse view must have experienced the
following problem:
If the view containing the table is presented on initial startup of the
RCP client, the first-time layout of TableLayout often happens *before*
the view has reached its final size. The effect is that the widths of
all table columns look too small relative to the room left.
Since TableLayout is only applied a single time (and I don't want to
have a change of this behaviour), it looks like we need to catch an
appropriate UI event that should be used as a trigger of our code to
apply TableLayout to such a table.
Is anyone aware of such an event - presumably part of the
view/perspective lifecycle - that could be used for such a delayed layout?
Let me emphasize that I consider the actual layout behaviour of
TableLayout as correct and I don't want to have another Layout (unless
this has a better internal trigger for what "first time" is considered).
Thanks & Greetings from Bremen,
Daniel Krügler
FUDForum. Page generated in 0.04443 seconds
