Home » Modeling » TMF (Xtext) » Invalid property category path
Invalid property category path [message #895765] Sun, 15 July 2012 17:01 Go to next message
I'm working with my Xtext project and with no cause in Eclipse Application the @Inject seems don't work, infact with IResourceDescriptions resourceDescriptions I can't find .mydsl files in the project.
Moreover in Eclipse's log file there is this error message
!MESSAGE Invalid property category path: ValidationPropertiesPage (bundle: org.eclipse.wst.xml.ui, propertyPage: org.eclipse.wst.xml.ui.propertyPage.project.validation)
How can I fix it?
Andrea
Re: Invalid property category path [message #895770 is a reply to message #895765] Sun, 15 July 2012 17:53 Go to previous messageGo to next message
what do you exactly do?
make sure you use yourdslextensionfactory in your plugin.xml.
the error messeage doesnt seem to be related to Xtext.
~Christian
Re: Invalid property category path [message #895771 is a reply to message #895770] Sun, 15 July 2012 18:02 Go to previous messageGo to next message
I'm doing some validation check among different files in my dsl project, I use
@Inject IResourceDescriptions
to access all files of project, but with no cause the IResourceDescriptions doesn't get theese files. I debug theese check early today and they run, so I don't understand the cause of this problem, so I check eclipse log and there is the error message "Invalid property category path", isn't it related?
Re: Invalid property category path [message #895801 is a reply to message #895771] Mon, 16 July 2012 02:12 Go to previous messageGo to next message
Make sure the project has Xtext nature and you have build
automatically on. Use the Open Model Element Dialog Crtl+Shift+F3 to
see that is in the index.
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Invalid property category path [message #895811 is a reply to message #895801] Mon, 16 July 2012 03:34 Go to previous message
Further, you should not use IResourceDescriptions, since it does not only have the resources visible from your project, but globally the index. Use IGlobalScopeProvider to get a view what's visible for your project.
Previous Topic:[xtext] import model from xcore
Next Topic:xbase generation exception
Current Time: Sun Jul 20 09:04:57 EDT 2025
Powered by FUDForum. Page generated in 0.09219 seconds
