Home » Eclipse Projects » Linux Tools Project » Errors while building Juno from source(eclipse-build)
Errors while building Juno from source [message #895724] Sun, 15 July 2012 07:54 Go to next message
I'm trying to build Juno from source but it fails while building the org.eclipse.jdt.debug package where some classes make use of the MessageFormat.format method from the com.ibm.icu.text package in an invalid way. Here is one of the errors.
    [javac] /var/tmp/portage/dev-util/eclipse-sdk-4.2/work/org.eclipse.linuxtools.eclipse-build-7b07d10488eb9d6e2880eac320b09c16d1ae78e3/eclipse-build/build/eclipse-4.2.0-I20120608-1400-src/plugins/org.eclipse.jdt.debug/model/org/eclipse/jdt/internal/debug/core/model/JDIDebugTarget.java:1252: error: no suitable method found for format(String,String)
    [javac] 			targetRequestFailed(MessageFormat.format(
    [javac] 			                                 ^
    [javac]     method MessageFormat.format(Object,StringBuffer,FieldPosition) is not applicable
    [javac]       (actual and formal argument lists differ in length)
    [javac]     method MessageFormat.format(String,Map<String,Object>) is not applicable
    [javac]       (actual argument String cannot be converted to Map<String,Object> by method invocation conversion)
    [javac]     method MessageFormat.format(String,Object[]) is not applicable
    [javac]       (actual argument String cannot be converted to Object[] by method invocation conversion)
    [javac]     method MessageFormat.format(Map<String,Object>,StringBuffer,FieldPosition) is not applicable
    [javac]     method MessageFormat.format(Object[],StringBuffer,FieldPosition) is not applicable
    [javac]     method Format.format(Object) is not applicable
and rest of the errors are here pastebin.com/KBdp3u6h.
Also, there are some plugins which have dependencies which aren't listed in dependencies.properties and aren't present in dependencyManifests directory.
javax.servlet.jsp_2.0 (required by many plugins)
org.apache.batik.xml_1.6.0
org.apache.commons.jxpath_1.2.0 (required by org.eclipse.e4.emf.xpath)
javax.servlet_2.5.0 (required by org.eclipse.equinox.jmx.server.xmlrpc)
org.apache.xmlrpc (required by org.eclipse.equinox.jmx.server.xmlrpc)
jetty 6.0.0 (required by org.eclipse.equinox.jmx.server.xmlrpc)
org.apache.sshd.core_0.5.0 (required by org.eclipse.equinox.console.jaas.fragment)
What's more important for me to know right now is why am I getting the errors.
Re: Errors while building Juno from source [message #897620 is a reply to message #895724] Tue, 24 July 2012 15:02 Go to previous messageGo to next message
Do you have icu4j of at least version 4.4.2 ? If it's older, this might explain the errors.
Re: Errors while building Juno from source [message #897686 is a reply to message #897620] Wed, 25 July 2012 02:22 Go to previous messageGo to next message
Roland Grunberg wrote on Tue, 24 July 2012 15:02
Yea, I have icu4j 4.4.2.
It seems the changes introduced in this commit to MessageFormat.format are causing the errors.
Using icu4j from eclipse bin package works.
[Updated on: Wed, 25 July 2012 02:29] by Moderator
Re: Errors while building Juno from source [message #898385 is a reply to message #897686] Thu, 26 July 2012 06:05 Go to previous message
Okay, so the problem was that I was using icu4j-4.4.2 but MessageFormat.format method with the varargs parameter was introduced in 4.4.2.1. Hence, the errors.
Previous Topic:1.0 released!
Next Topic: error logged from debug core
Current Time: Sun Jul 20 05:50:03 EDT 2025
Powered by FUDForum. Page generated in 0.06134 seconds
