Home » Language IDEs » PHP Development Tools (PDT) » How can the manual for looking PHP functions be set locally
How can the manual for looking PHP functions be set locally [message #89542] Sun, 11 January 2009 22:27 Go to next message
How can the manual for looking PHP functions ie under Preferences | PHP |
manual be set local version of the PHP manual?
Is there a download for that? Can I download the current manual for PHP
and get eclipse to look it up?
Re: How can the manual for looking PHP functions be set locally [message #89658 is a reply to message #89542] Mon, 12 January 2009 11:04 Go to previous messageGo to next message
Originally posted by: nickboldt+eclipse+newsgroup.gmail.com
You could google for "php <functionname>" and get what you need pretty
quickly. You could also use Eclipse's internal browser if you want to
have it *in* Eclipse, and don't want the built-in version of the manual.
Nick Boldt :: http://wiki.eclipse.org/User:Nickb
Re: How can the manual for looking PHP functions be set locally [message #89701 is a reply to message #89542] Mon, 12 January 2009 11:40 Go to previous messageGo to next message
Yes, that's possible. Download the "Many HTML files"-version of the PHP
documentation from http://www.php.net/download-docs.php
After extracting it somewhere, go to "Preferences" -> "PHP" -> "PHP
Manual" and add a "New" entry. Select "Local Directory" and enter the
path where you have extracted the files to. Make sure that "File
Extension" is set to "html".
After marking the new entry as the "Default", the "Open PHP
manual"-action should open the appropriate local html-file.
HTH,
Mark
Re: How can the manual for looking PHP functions be set locally [message #89716 is a reply to message #89701] Mon, 12 January 2009 12:03 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
I believe the PHP manual sources are kept in DocBook format and
generated to the appropriate target formats. What would be nice is if
an eclipse plugin help plugin could be generated, and then installed as
an option into an existing eclipse instance.
Information on how to generate the eclipse help from Docbook can be
found here:
http://wiki.eclipse.org/Authoring_Eclipse_Help_Using_DocBook
Zend could offer this as a download or via their Update site.
Dave
> HTH,
> Mark
Re: How can the manual for looking PHP functions be set locally [message #89731 is a reply to message #89542] Mon, 12 January 2009 12:46 Go to previous message
Frank Church napsal(a):
Download ZendStudiu trial and there is PHP manual localy, suffice copy one dir from zend
studiu to the eclipse folder and setup php manual preference page as is in Zend Studio.
I'm using that, so it's 100% functional ;)
Previous Topic:Re: html in php
Next Topic:PDT 2.0.1 on the interim
Current Time: Sat Jul 19 15:25:10 EDT 2025
Powered by FUDForum. Page generated in 0.04372 seconds
