Home » Eclipse Projects » Rich Client Platform (RCP) » Export Product to Mac (Carbon)
Export Product to Mac (Carbon) [message #895086] Wed, 11 July 2012 12:17 Go to next message
Hi all,
I'm having trouble getting Hello RCP application working on a mac.
1) Downloaded Juno and 4.2 delta pack (+ added it to target platform) on Windows
2) Built the Hello RCP application and product - exported and tested it on Windows
3) Tried to export to carbon but got error message...
Processing inclusion from feature org.eclipse.equinox.executable: Unable to find plug-in: org.eclipse.equinox.launcher.carbon.macosx_0.0.0. Please check the error log for more details.
... seems a little strange for a stable build that carbon is not supported?
I've successfully exported with the cocoa versions but these won't run on the mac I'm targeting - version = 10.7.4 (which I believe requires carbon).
Any possible solutions?
Gaff
Re: Export Product to Mac (Carbon) [message #895171 is a reply to message #895086] Wed, 11 July 2012 17:16 Go to previous messageGo to next message
Which macs are you targeting? cocoa is the only platform you can expect
new bugfixes, carbon bugs get closed as won't fix!
Tom
Am 11.07.12 18:17, schrieb Conor Gaffney:
> Hi all,
> Windows
> on Windows
> carbon).
> Gaff
Re: Export Product to Mac (Carbon) [message #895266 is a reply to message #895171] Thu, 12 July 2012 06:13 Go to previous messageGo to next message
Hi Tom,
Sorry, I'm not too up on Macs OS. So carbon is older and has been discontinued? and cocoa (32) should work on any new mac (OS X)?
I have now tried the RCP Hello World example on 2 Macs: 10.7.4 and 10.6.8 - the x86, x86_64 and ppc versions ... none of these have worked.
Running from the command line of the 10.6.8 version I got the following error:
LSOpenURLsWithRole() failed with error -10810
Any assistance would be greatly appreciated.
Gaff
Re: Export Product to Mac (Carbon) [message #895271 is a reply to message #895266] Thu, 12 July 2012 06:30 Go to previous message
Why do you need 32bit, do you use any native 32bit libs? The default on
os-x is 64bit and I'd only use 32 in case I have to use external 32bit
libs.
IIRC cocoa 32 should work, because java 6 has a 32bit mode, but I have
to confess that I haven't tested it lately.
Tom
Am 12.07.12 12:13, schrieb Conor Gaffney:
> Hi Tom,
> error:
> Gaff
Previous Topic:remove linkhelper button/action
Next Topic:How can I add submenus for pop up menu programatically?
Current Time: Sat Jul 19 23:50:48 EDT 2025
Powered by FUDForum. Page generated in 0.03599 seconds
