CTRL+Backspace and CTRL+Delete not working in aText Editor [message #892339] |
Wed, 27 June 2012 15:34  |
Eclipse Version: 3.6.2
Client OS: Windows-7
CTRL+Backspace and CTRL+Delete, for delete previous word and delete next word, in a text editor are not working. I have attached a simple code to demonstrate the behavior. I haven't tried if the behavior is any different with Eclipse 3.7.
There may be other keyboard short cuts that are not working. I didn't perform checks of all of the possible short cuts. However, CTRL-C and CTRL-V, for Copy and Paste, do work. There has been no change to the default Eclipse key binding.
I am not sure if this is a problem with Eclipse or something I am doing wrong. I would like an explanation why these keyboard short cuts are not working for me and/or suggestion on hot to make them work in such a text editor.
Al Habte
Re: CTRL+Backspace and CTRL+Delete not working in aText Editor [message #895177 is a reply to message #893128] |
Wed, 11 July 2012 17:43  |
Lakshmi:
Thanks for the suggestion. The sample I gave is to demonstrate the behavior I am observing in a
RCP application that has a large number of Text widgets. Regression test is a factor, along with
the effort to replacing Text widgets by StyledText widgets, in this application. I welcome any
other alternative(s), so I can weight my options and effort associated with each.
Al Habte.
FUDForum. Page generated in 0.04948 seconds
