Home » Modeling » Graphiti » Problem with EReference
Problem with EReference [message #894869] |
Tue, 10 July 2012 16:30  |
I have a problem when adding an ERefernce to my editor. In fact, when opening the editor, the Ereference is already added to palette,then, when i try to draw a connection from SecondEClass2 to SecondEClass1, the arrow cannot be visualized in the editor (see image 1) like in the tutorial. However, when expanding the SecondEClass2 in the project explorer, we could observe that an Erefrence is added to the SecondEClass2 (see image 2)
could anyone explain me what is the matter ?
Thanks in advance.
Attachment: image 1.JPG
(Size: 19.38KB, Downloaded 339 times)
Attachment: image 2.JPG
(Size: 13.04KB, Downloaded 314 times)
Re: Problem with EReference [message #895179 is a reply to message #894869] |
Wed, 11 July 2012 17:46   |
Thank you for your answer.
I have proceeded exactly like in the tutorial. Here is the code:
The TutorialCreateEReferenceFeature.java :
public class TutorialCreateEReferenceFeature extends
AbstractCreateConnectionFeature {
public TutorialCreateEReferenceFeature (IFeatureProvider fp) {
// provide name and description for the UI, e.g. the palette
super(fp, "EReference", "Create EReference");
public boolean canCreate(ICreateConnectionContext context) {
// return true if both anchors belong to an EClass
// and those EClasses are not identical
EClass source = getEClass(context.getSourceAnchor());
EClass target = getEClass(context.getTargetAnchor());
if (source != null && target != null && source != target) {
return true;
return false;
public boolean canStartConnection(ICreateConnectionContext context) {
// return true if start anchor belongs to a EClass
if (getEClass(context.getSourceAnchor()) != null) {
return true;
return false;
public Connection create(ICreateConnectionContext context) {
Connection newConnection = null;
// get EClasses which should be connected
if (source != null && target != null) {
// create new business object
EReference eReference = createEReference(source, target);
// add connection for business object
AddConnectionContext addContext =
new AddConnectionContext(context.getSourceAnchor(), context
addContext.setNewObject(eReference);
newConnection =
(Connection) getFeatureProvider().addIfPossible(addContext);
return newConnection;
* Returns the EClass belonging to the anchor, or null if not available.
private EClass getEClass(Anchor anchor) {
if (anchor != null) {
Object object =
getBusinessObjectForPictogramElement(anchor.getParent());
if (object instanceof EClass) {
return (EClass) object;
return null;
* Creates a EReference between two EClasses.
private EReference createEReference(EClass source, EClass target) {
EReference eReference = EcoreFactory.eINSTANCE.createEReference();
eReference.setName("new EReference");
eReference.setEType(target);
eReference.setLowerBound(0);
eReference.setUpperBound(1);
source.getEStructuralFeatures().add(eReference);
return eReference;
The TutorialFeatureProvider.java :
public class TutorialFeatureProvider extends DefaultFeatureProvider {
public TutorialFeatureProvider(IDiagramTypeProvider dtp) {
super(dtp);
public IAddFeature getAddFeature(IAddContext context) {
//is object for add request a EClass?
if (context.getNewObject() instanceof EClass) {
return new TutorialAddEClassFeature(this);
return super.getAddFeature(context);
public ICreateFeature[] getCreateFeatures() {
return new ICreateFeature[] { new TutorialCreateEClassFeature(this) };
public ICreateConnectionFeature[] getCreateConnectionFeatures() {
return new ICreateConnectionFeature[] {
new TutorialCreateEReferenceFeature (this) };
The TutorialAddEClassFeature.java :
public class TutorialAddEClassFeature extends AbstractAddShapeFeature {
private static final IColorConstant CLASS_TEXT_FOREGROUND =
new ColorConstant(51, 51, 153);
private static final IColorConstant CLASS_FOREGROUND =
new ColorConstant(255, 102, 0);
private static final IColorConstant CLASS_BACKGROUND =
new ColorConstant(255, 204, 153);
public TutorialAddEClassFeature(IFeatureProvider fp) {
super(fp);
public boolean canAdd(IAddContext context) {
// check if user wants to add a EClass
// check if user wants to add to a diagram
if (context.getTargetContainer() instanceof Diagram) {
return true;
return false;
@SuppressWarnings("deprecation")
public PictogramElement add(IAddContext context) {
EClass addedClass = (EClass) context.getNewObject();
Diagram targetDiagram = (Diagram) context.getTargetContainer();
// CONTAINER SHAPE WITH ROUNDED RECTANGLE
IPeCreateService peCreateService = Graphiti.getPeCreateService();
ContainerShape containerShape =
peCreateService.createContainerShape(targetDiagram, true);
// define a default size for the shape
int width = 100;
int height = 50;
IGaService gaService = Graphiti.getGaService();
// create and set graphics algorithm
RoundedRectangle roundedRectangle =
gaService.createRoundedRectangle(containerShape, 5, 5);
roundedRectangle.setForeground(manageColor(CLASS_FOREGROUND));
roundedRectangle.setBackground(manageColor(CLASS_BACKGROUND));
roundedRectangle.setLineWidth(2);
gaService.setLocationAndSize(roundedRectangle,
context.getX(), context.getY(), width, height);
// if added Class has no resource we add it to the resource
// of the diagram
// in a real scenario the business model would have its own resource
if (addedClass.eResource() == null) {
getDiagram().eResource().getContents().add(addedClass);
// create link and wire it
link(containerShape, addedClass);
// SHAPE WITH LINE
// create shape for line
Shape shape = peCreateService.createShape(containerShape, false);
Polyline polyline =
gaService.createPolyline(shape, new int[] { 0, 20, width, 20 });
polyline.setForeground(manageColor(CLASS_FOREGROUND));
polyline.setLineWidth(2);
// SHAPE WITH TEXT
// create shape for text
// create and set text graphics algorithm
Text text = gaService.createDefaultText(getDiagram(), shape,
addedClass.getName());
text.setForeground(manageColor(CLASS_TEXT_FOREGROUND));
text.setHorizontalAlignment(Orientation.ALIGNMENT_CENTER);
text.setVerticalAlignment(Orientation.ALIGNMENT_CENTER);
text.getFont().setBold(true);
gaService.setLocationAndSize(text, 0, 0, width, 20);
link(shape, addedClass);
// add a chopbox anchor to the shape
peCreateService.createChopboxAnchor(containerShape);
return containerShape;
There is another indication. I have tried to create a new Graphiti diagram based on the diagram type "tutorial" (that's the diagram type given with graphiti example) -See attachment test-tutorial.JPG. On the other hand, I have created another graphiti diagram based on the diagram type "mytutorial" (that's the digram type of my example)
- See attachment test-mytutorial.JPG.
I have realised that the editors of the two diagrams are not the same like indicated in attachment.
Re: Problem with EReference [message #895180 is a reply to message #895179] |
Wed, 11 July 2012 17:54   |
Yes there is error log :
!ENTRY org.eclipse.ui 4 0 2012-04-21 13:57:05.123
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.RuntimeException: java.net.UnknownHostException: www.eclipse.org
at org.eclipse.amalgam.discovery.modeling.handlers.ModelingDiscoveryHandler$1.load(ModelingDiscoveryHandler.java:63)
at org.eclipse.amalgam.discovery.ui.viewer.DiscoveryContentProvider.getDiscovery(DiscoveryContentProvider.java:33)
at org.eclipse.amalgam.discovery.ui.viewer.DiscoveryViewer.getDiscovery(DiscoveryViewer.java:1116)
at org.eclipse.amalgam.discovery.ui.viewer.DiscoveryViewer.<init>(DiscoveryViewer.java:498)
at org.eclipse.amalgam.discovery.ui.wizards.internal.DiscoveryWizardMainPage.createControl(DiscoveryWizardMainPage.java:56)
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:174)
at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:736)
at org.eclipse.jface.wizard.WizardDialog.createContents(WizardDialog.java:608)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
at org.eclipse.jface.window.Window.open(Window.java:790)
at org.eclipse.amalgam.discovery.modeling.handlers.ModelingDiscoveryHandler.execute(ModelingDiscoveryHandler.java:83)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:829)
at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:815)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:805)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: java.net.UnknownHostException: www.eclipse.org
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.http.HttpClient.<init>(Unknown Source)
at sun.net.www.http.HttpClient.New(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at org.eclipse.emf.ecore.resource.impl.URIHandlerImpl.createInputStream(URIHandlerImpl.java:178)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:350)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1262)
at org.eclipse.amalgam.discovery.modeling.handlers.ModelingDiscoveryHandler$1.load(ModelingDiscoveryHandler.java:58)
... 43 more
!SESSION 2012-06-21 23:27:06.708 -----------------------------------------------
eclipse.buildId=M20120208-0800
java.version=1.6.0_31
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Framework arguments: -product org.eclipse.epp.package.modeling.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.modeling.product
!ENTRY org.eclipse.epp.usagedata.recording 1 0 2012-06-21 23:28:26.273
!MESSAGE Usage data uploaded to http://udc.eclipse.org/upload.php in 16668 milliseconds.
!SESSION 2012-06-24 16:25:51.382 -----------------------------------------------
!ENTRY org.eclipse.jface 4 0 2012-06-27 07:47:41.234
!MESSAGE Unhandled event loop exception during blocked modal context.
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:4282)
at org.eclipse.swt.SWT.error(SWT.java:4197)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:138)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.block(ModalContext.java:173)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:388)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:275)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor.disconnectFromWorkspace(IDEWorkbenchAdvisor.java:515)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor.postShutdown(IDEWorkbenchAdvisor.java:348)
at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:3028)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1123)
at org.eclipse.ui.internal.Workbench.access$15(Workbench.java:1040)
at org.eclipse.ui.internal.Workbench$25.run(Workbench.java:1284)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1282)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1254)
at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:727)
at org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWindow.java:715)
at org.eclipse.ui.internal.WorkbenchWindow$6.run(WorkbenchWindow.java:867)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:865)
at org.eclipse.jface.window.Window.handleShellCloseEvent(Window.java:741)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:687)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:98)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations.java:308)
at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.java:1677)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4530)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1610)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2061)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4972)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2526)
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:498)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4623)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2531)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3752)
at org.eclipse.epp.usagedata.internal.ui.uploaders.AskUserUploader$1.getShell(AskUserUploader.java:69)
at org.eclipse.epp.usagedata.internal.ui.uploaders.AskUserUploader$1.run(AskUserUploader.java:63)
at org.eclipse.ui.internal.UILockListener.doPendingWork(UILockListener.java:164)
at org.eclipse.ui.internal.UISynchronizer$3.run(UISynchronizer.java:158)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
... 73 more
!SESSION 2012-07-05 21:29:22.029 -----------------------------------------------
!ENTRY org.eclipse.epp.usagedata.recording 1 0 2012-07-05 21:30:26.491
!MESSAGE Usage data uploaded to http://udc.eclipse.org/upload.php in 2637 milliseconds.
!ENTRY org.eclipse.help 4 0 2012-07-05 21:31:38.737
!MESSAGE Error reading help table of contents file /"org.eclipse.gmf.doc/toc-runtime.xml" (skipping file)
!STACK 0
java.io.FileNotFoundException
at org.eclipse.help.internal.toc.TocFileParser.parse(TocFileParser.java:49)
at org.eclipse.help.internal.toc.TocFileProvider.getTocContributions(TocFileProvider.java:47)
at org.eclipse.help.internal.toc.TocManager.getAndCacheTocContributions(TocManager.java:210)
at org.eclipse.help.internal.toc.TocManager.getTocContributionsForToc(TocManager.java:199)
at org.eclipse.help.internal.toc.TocManager.getRootTocContributions(TocManager.java:306)
at org.eclipse.help.internal.toc.TocManager.getTocs(TocManager.java:68)
at org.eclipse.help.internal.toc.TocManager.getTopic(TocManager.java:123)
at org.eclipse.help.internal.toc.TocManager.getTopicPath(TocManager.java:138)
at org.eclipse.help.internal.webapp.data.UrlUtil.getTopicPath(UrlUtil.java:216)
at org.eclipse.help.internal.webapp.servlet.BreadcrumbsFilter.filter(BreadcrumbsFilter.java:75)
at org.eclipse.help.internal.webapp.servlet.EclipseConnector.transfer(EclipseConnector.java:193)
at org.eclipse.help.internal.webapp.servlet.ContentServlet.doGet(ContentServlet.java:45)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:126)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:68)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:317)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:511)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:390)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:182)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:326)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:542)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:924)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:549)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:212)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:582)
!ENTRY org.eclipse.help 4 0 2012-07-05 21:31:38.774
!MESSAGE Error reading help table of contents file /"org.eclipse.gmf.doc/toc-tooling.xml" (skipping file)
!STACK 0
!SESSION 2012-07-06 21:01:40.099 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2012-07-06 21:01:44.367
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.help 4 0 2012-07-06 21:04:01.670
!STACK 0
!ENTRY org.eclipse.help 4 0 2012-07-06 21:04:01.680
!STACK 0
!ENTRY org.eclipse.epp.usagedata.recording 1 0 2012-07-10 21:34:44.206
!MESSAGE Usage data uploaded to http://udc.eclipse.org/upload.php in 13729 milliseconds.
Current Time: Sun Jul 20 10:44:44 EDT 2025
Powered by FUDForum. Page generated in 0.04224 seconds
