Home » Modeling » EMF » Copy and Paste from clipboard in EMF
Copy and Paste from clipboard in EMF [message #894512] Mon, 09 July 2012 09:48 Go to next message
Hi again,
Is there copy and paste from clipboard in EMF ?
if yes, then where to look for ?
Re: Copy and Paste from clipboard in EMF [message #894523 is a reply to message #894512] Mon, 09 July 2012 10:00 Go to previous messageGo to next message
The generated editor supports copy and paste. It just uses a local
clipboard, i.e., local to the one editor. You can copy and things like
CopyCommand and PasteCommand.
On 09/07/2012 3:48 PM, becks m wrote:
> Hi again,
Re: Copy and Paste from clipboard in EMF [message #894545 is a reply to message #894523] Mon, 09 July 2012 10:48 Go to previous messageGo to next message
Unfortunately, I don't use the generated editor, I want to make use of it in another ui plugin.
should I consider emf to do that , or I use ordinary eclipse copy and paste
Ed Merks wrote on Mon, 09 July 2012 10:00
> Hi again,
Re: Copy and Paste from clipboard in EMF [message #894611 is a reply to message #894545] Mon, 09 July 2012 15:50 Go to previous message
If you aren't using EMF's command framework, you'll probably want to use
something ordinary.
> paste
>> like CopyCommand and PasteCommand.
>> > Hi again,
Previous Topic:[Xcore] How can I use *set* keyword
Next Topic:Constraint with EMF Framework validation
Current Time: Sun Jul 20 14:30:06 EDT 2025
Powered by FUDForum. Page generated in 0.40789 seconds
