Home » Eclipse Projects » Mylyn » Media wiki Internal Links connecting Problem
Media wiki Internal Links connecting Problem [message #894451] Mon, 09 July 2012 05:39 Go to next message
pleased to meet you,am a Newcomer here
My ant task would be creating Eclipse Help Document in Media wiki format
wikitext-to-xslfo
wikitext-to-eclipse-help
I'm trying to set up different internal Links between single media-wiki file, which unfortunately I couldn't make.
for example
= Chapter 1 =
blabla
== section 1.1 ==
blabla
[[Chapter_3#sec1]]
= Chapter 2 =
= Chapter 3 =
== section 3.1 ==
Any Suggestions to make the internal links work ?
Best Regards,
Suresh
[Updated on: Tue, 10 July 2012 03:39] by Moderator
Re: Media wiki Internal Links connecting Problem [message #894598 is a reply to message #894451] Mon, 09 July 2012 14:58 Go to previous messageGo to next message
I am not sure to understand what you try to do. I assume you know the example on this page: CrowSourcingExample (have a look on the referenced GitHub project: wikitext examples source code)
Personally I am doing the conversion in a standard JavaSE project (having org.eclipse.mylyn.wikitext.core and
org.eclipse.mylyn.wikitext.mediawiki.core jars on the classpath) because I wanted to have more customization options as what is provided by the default ANT task.
If you have a MediaWikiLangage instance you can influence where the link is pointing (an other internal page or the original external page) with setPageMapping(..). You implement the page PageMapping Interface with an Implementation that suit your needs.
I am not sure that this is what you are looking for. Do not hesitate to ask other questions and to provide some example of what you are doing.
Re: Media wiki Internal Links connecting Problem [message #894699 is a reply to message #894598] Tue, 10 July 2012 04:02 Go to previous messageGo to next message
Actually I'm trying to set up different internal Links between sections in a single media-wiki file and to generate the Eclipse help as well as the PDF.
for example
= Chapter 1 =
blabla
== section 1.1 ==
blabla
[[Chapter_3#sec1]]
= Chapter 2 =
= Chapter 3 =
== section 3.1 ==
These internal links doesn't work in both Eclipse Help and PDF.Am bit stuck up with the syntax(create internal links) to do so.
Re: Media wiki Internal Links connecting Problem [message #894753 is a reply to message #894699] Tue, 10 July 2012 07:40 Go to previous messageGo to next message
Thanks for the example... This links are valid in MediaWiki:
* [[#section_1.1]]
* [[#Chapter_2|second chapter]]
* [[SectionTestPage#Chapter_3]]
* [[SectionTestPage#section_3.1|this section]]
See: Help:Links
Here is what I got from the MediaWiki instance:
<h2><span class="editsection">[<a href="/<path to wiki>/mediawiki/index.php?title=SectionTest&amp;action=edit&amp;section=2" title="Edit section: section 1.1">edit</a>]</span> <span class="mw-headline" id="section_1.1"> section 1.1 </span></h2>
From what I remember, your Problem is that WikiText does not exactly the same conversion:
* the span tag is not added.
* h2 got an additional id
(this should be confirmed with a small test).
Therefore, the MediaWikiLangage should also convert the anchor part of the link.
Re: Media wiki Internal Links connecting Problem [message #894837 is a reply to message #894753] Tue, 10 July 2012 13:22 Go to previous message
Just to be sure, I had a look at the output of Mylyn WikiTest for the same input:
<p>blabla</p><h2 id="section_1.1">section 1.1</h2><p>blabla</p>
Therefore the internal links can not work (in both MediaWiki and WikiText).
To my mind, the MediaWikiIdGenerationStrategy could be improved to match what MediaWiki is doing (consider the numeration of the section).
Do you want to have a bug opened for this ?
Previous Topic:Error on New Bugzilla Repository in Juno
Next Topic:Review for Eclipse (R4E) 0.11.0 is now available
Current Time: Sat Jul 19 19:32:22 EDT 2025
Powered by FUDForum. Page generated in 0.03515 seconds
