Home » Eclipse Projects » P2 » Running update manager from command line in Juno
Running update manager from command line in Juno [message #893248] Tue, 03 July 2012 06:45 Go to next message
in Indigo, it was possible to run the update from the command line
http://help.eclipse.org/indigo/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Freference%2Fmisc%2Fupdate_standalone.html
but this does not to be present in Juno...
is there a similar way to run the update manager from the command line?
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: Running update manager from command line in Juno [message #894219 is a reply to message #893248] Sat, 07 July 2012 15:44 Go to previous messageGo to next message
You can achieve this using the director application: http://help.eclipse.org/indigo/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Fguide%2Fp2_director.html
Re: Running update manager from command line in Juno [message #894361 is a reply to message #894219] Sun, 08 July 2012 13:14 Go to previous messageGo to next message
you mean that using
-profileProperties: a comma separated list of <key>=<value> pair. The
property org.eclipse.update.install.features=true will cause the update
manager features to be installed.
will make the update manager to check for updates?
Re: Running update manager from command line in Juno [message #895294 is a reply to message #894361] Thu, 12 July 2012 07:54 Go to previous message
The legacy Update Manager was removed in Juno. It's not distributed in any of the pre-packaged distributions.
I think Pascal meant can use the director in the same manner you used to use the update manager command line.
PW
Previous Topic:Can p2.inf start bundle not included in feature?
Next Topic:Can't get P2 to load remote repository
Current Time: Sun Jul 20 05:49:25 EDT 2025
Powered by FUDForum. Page generated in 0.04194 seconds
