Home » Archived » BIRT » Font problem
Font problem [message #89223] Wed, 09 November 2005 08:15 Go to next message
Originally posted by: nospam.mail.com
I defined a report where I chose the Arial font. The HTML rendering is OK.
When I render it to PDF, it's a Times Roman or equivalent that is used.
This font is more wide, so the rendering is bad.
Does anybody knows which font I have to use to get Arial fonts like in
HTML rendering ?
A. ROY
Re: Font problem [message #89386 is a reply to message #89223] Wed, 09 November 2005 15:12 Go to previous messageGo to next message
Originally posted by: jake.westviewclose.co.uk
A. Roy, I'm going through the same issue at the moment. I've found a
couple of newsgroup mails that discuss the problem....figure we may as
well work it out together!
It seems like there are two steps
1) Create the Font metrics file for use by Birt
(Web link http://xml.apache.org/fop/fonts.html#truetype-metrics). This
is fairly confusing for me, and i've hit a wall, but so far i've
downloaded FOP itself - http://xml.apache.org/fop
I've downloaded version 0.20.5 (just the binaries file)
This gives you all of the jar files etc. I've saved this folder directly
onto my C:\ drive for ease and renamed it fop from fop0.20.5-bin
Open a command prompt and enter something like
C:\> java -cp
C:\fop\build\fop.jar;C:\fop\lib\avalon-framework-cvs-2002080 6.jar;C:\fop\lib\xml-apis.jar;
C:\fop\lib\xercesImpl-2.2.1.jar;C:\fop\lib\xalan-2.4.1.jar
org.apache.fop.fonts.apps.TTFReader -enc ansi C:\Windows\Fonts\arial.ttf
C:\fop\myfonts\arial.xml
Sadly...this is where my problems start as although it recognises the
Arial tff file when it tries to write out the Metric something goes
wrong as it states that the filename directory name or volume label
syntax is incorrect??????
2) Once we've done that though (you may be more successful than I) its
onto stage 2
You need to locate the fop.xml file (i think)
Mine is in my
eclipse\plugins\org.eclipse.birt.report.engine.emitter.fo_1. 0.1 folder
and add in
<fonts>
<font metrics-file="C:\fop\myfonts\arial.xml"
embed-file="C:\Windows\Fonts\ARIAL.TTF" kerning="yes">
<font-triplet name="arial" style="normal" weight="normal"/>
<font-triplet name="arial" style="normal" weight="bold"/>
</font>
However, i haven't completed stage 2 yet as i'm still stuck on stage
one......
If you have any joy, (or if anyone else can help, please let me know.
Jake
AR wrote:
> OK. When I render it to PDF, it's a Times Roman or equivalent that is
> used. This font is more wide, so the rendering is bad.
> HTML rendering ?
> Regards
Re: Font problem [message #89508 is a reply to message #89386] Wed, 09 November 2005 16:59 Go to previous message
A.Roy,
Ok....finally got through stage 1....
I hadn't read the apache page thoroughly. If you are running Java 1.4
then you don't need to use all of the jar files.
for me the metric was created by typing on the command prompt
java -cp C:\fop\build.jar;C:fop\lib\avalon-framework-cvs-20020806.jar
org.apache.fop.fonts.apps.TTFReader C:\Windows\Fonts\arial.ttf
C:\fop\myfonts.arial.xml
I'm now struggling manfully with getting this to work in the xml.....
if you have any great thoughts, please let me know.
> C:\> java -cp
> onto stage 2
> Mine is in my
> and add in
> <fonts>
> </font>
> one......
> Jake
> AR wrote:
>> Hi,
>> in HTML rendering ?
>> Regards
Previous Topic:Get display name out of database
Next Topic:BIRT Installation
Current Time: Sat Jul 19 15:47:18 EDT 2025
Powered by FUDForum. Page generated in 0.04540 seconds
