Home » Archived » M2M (model-to-model transformation) » [ATL] Transformation in xmi format?
[ATL] Transformation in xmi format? [message #88424] Sat, 16 August 2008 19:02 Go to next message
Is there any way of serializing an ATL transformation in xmi format
respecting the ATL .ecore metamodel?
If not, is there any way of, via any API, to access ATL
transformation in order to be able to parse it?
Thanks very much in advance,
Luis Pedro
Re: [ATL] Transformation in xmi format? [message #88459 is a reply to message #88424] Sun, 17 August 2008 12:44 Go to previous messageGo to next message
Hi Luis,
You can use TCS injection for this.
Here is a tutorial: http://wiki.eclipse.org/TCS/TCS_Toolkit_Tutorial
The ATL km3 and tcs are available on the atl CVS under dsls
Alfons
"Luis Pedro" <luis.pedro@cui.unige.ch> schreef in bericht
news:g87maj$6br$1@build.eclipse.org...
> If not, is there any way of, via any API, to access ATL transformation
> Regards,
> Luis Pedro
Re: [ATL] Transformation in xmi format? [message #88778 is a reply to message #88459] Fri, 22 August 2008 09:52 Go to previous messageGo to next message
Alfons Laarman wrote:
> Hi Luis,
> Regards,
> Alfons
>> Hi,
>> Regards,
>> Luis Pedro
There is already an injector available for ATL, which can be accessed
using AM3 Ant scripts. The following example Eclipse project reads two
ATL transformations and creates one new ATL transformation:
http://ssel.vub.ac.be/viewvc/atl-superimposition-semantics/
The build.xml script in this project gives you a good idea of how to
load ATL modules as models. You can then save them to another file
and/or use them in a transformation.
The TCS stuff in the build.xml file is used to convert ATL-as-models
back to ATL text format.
Dennis
Re: [ATL] Transformation in xmi format? [message #89275 is a reply to message #88778] Thu, 28 August 2008 18:47 Go to previous messageGo to next message
Hi Dennis,
Thanks for the answer. Yes, this build.xml looks nice and easy to
follow. My problem is that I'm not able to make the am3.loadModel to
work. I've the Problem: failed to create task or type am3.loadModel
error from ANT. I tried to get the org.eclipse.gmt.am3.tools.ant package
in a jar format to add it to my eclipse installed pluggins but with no
success! Do you have any idea were can I get the pluggins needed to make
this working?
Thanks very much in advance for your time,
Luis
Re: [ATL] Transformation in xmi format? [message #89367 is a reply to message #89275] Fri, 29 August 2008 07:24 Go to previous messageGo to next message
Make sure, in launch configuration, that you choose "run in same JRE".
Alfons
news:g979ug$arq$1@build.eclipse.org...
> Hi Dennis,
> follow. My problem is that I'm not able to make the am3.loadModel to work.
> this working?
> Regards,
> Luis
Re: [ATL] Transformation in xmi format? [message #89382 is a reply to message #89367] Fri, 29 August 2008 09:30 Go to previous messageGo to next message
That's what I'm doing. But I think I need to go and download the
org.eclipse.gmt.am3.tools.ant package but I don't know where from.
Luis
Re: [ATL] Transformation in xmi format? [message #89427 is a reply to message #89382] Sat, 30 August 2008 16:15 Go to previous message
Depends on the ATL version you installed, but you could try to compile the
latest from CVS. dev.eclipse.org. in /cvsroot/technology
Alfons
news:g98tm0$lv7$1@build.eclipse.org...
> Regards
> Luis
Previous Topic:[ATL] Problems to migrate to Ganymede
Next Topic:[ATL] EMF Resource
Current Time: Sat Jul 19 06:26:43 EDT 2025
Powered by FUDForum. Page generated in 0.05932 seconds
