Home » Eclipse Projects » Eclipse Platform » Opening a Java File given a filename and line number
Opening a Java File given a filename and line number [message #89356] Fri, 04 July 2003 19:01 Go to next message
Originally posted by: andy.slamjibe.com
I am in the process of writing my own plugin view which needs to be able
to open java source files in the editor and select a given line. I have
the filename and the line number available to me and would like to know
how turn these into the action I require.
Can anyone offer help / starting point - thanks
Andy
Re: Opening a Java File given a filename and line number [message #91364 is a reply to message #89356] Thu, 10 July 2003 18:40 Go to previous message
Originally posted by: John_Arthorne.oti.com_
One way to do this is to create a text marker in the file with the
appropriate offset and length, and then use
IWorkbenchPage.openEditor(IMarker) or
IEditorPart.gotoMarker(IMarker)
You can delete the marker after opening using IMarker.delete.
There is a utility class for creating text markers called
MarkerUtilities in org.eclipse.ui.texteditor.
> Andy
Previous Topic:ClassCastException in VariableContextManager
Next Topic:Error while closing workbench
Current Time: Sat Jul 19 09:17:27 EDT 2025
Powered by FUDForum. Page generated in 0.02553 seconds
