Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Text hint support on Windows 7
Text hint support on Windows 7 [message #893217] Tue, 03 July 2012 05:14 Go to next message
Hi all,
I have a Text widget and I set a field hint using the method
Text#setMessage(java.lang.String)
This worked like a charm on Windows XP, but on Windows 7 the hint isn't
displayed.
The Text widget is set as not editable.
Example code:
Text field = new Text(parent, SWT.BORDER | SWT.SINGLE);
field.setEditable(false);
field.setMessage("Filter results");
Kindly, elvisd
Re: Text hint support on Windows 7 [message #893219 is a reply to message #893217] Tue, 03 July 2012 05:17 Go to previous messageGo to next message
Sorry, forgot to say that I'm using eclipse Indigo
On Tue, 03 Jul 2012 09:14:44 +0000, Elvis Dominguez wrote:
> Hi all,
> displayed.
> Example code:
> Kindly, elvisd
Re: Text hint support on Windows 7 [message #893236 is a reply to message #893219] Tue, 03 July 2012 06:05 Go to previous messageGo to next message
I think it's expected behavior. If you can't edit the text, then why it should give you a hint?
Re: Text hint support on Windows 7 [message #893266 is a reply to message #893236] Tue, 03 July 2012 08:20 Go to previous messageGo to next message
You are true, but the Text can become editable after some status change,
thus could be ok to display some hint even if not editable.
If is a expected behavior it's ok for me. But for the same SWT version
you have different behavior. In Linux and Windows XP the hint is
displayed, in W7 not.
Is maybe controlled by the OS?
On Tue, 03 Jul 2012 12:05:56 +0200, Jan Krakora wrote:
Re: Text hint support on Windows 7 [message #893275 is a reply to message #893266] Tue, 03 July 2012 08:49 Go to previous messageGo to next message
Yes, I think its controlled by the OS.
You could create a bug on the eclipse bugzilla for this. The SWT guys then give us the final answer.
Re: Text hint support on Windows 7 [message #893331 is a reply to message #893275] Tue, 03 July 2012 10:53 Go to previous messageGo to next message
Hi Jan,
thank you for your messages.
I've opened a bug [1] about this issue.
Kindly, elvisd
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=384175
Re: Text hint support on Windows 7 [message #957845 is a reply to message #893331] Thu, 25 October 2012 10:42 Go to previous message
Try to use Text widget with SWT.SEARCH style. At least for me it works...
Previous Topic:tree table flexibility
Next Topic:JVM Crash on xulrunner org.eclipse.swt.browser
Current Time: Sat Jul 19 13:46:27 EDT 2025
Powered by FUDForum. Page generated in 0.03908 seconds
