Home » Archived » BIRT » BIRT support for PDF and Excel report Generation
BIRT support for PDF and Excel report Generation [message #892160] Wed, 27 June 2012 05:24 Go to next message
Which technology/software BIRT uses internally for generation of pdf or excel reports? Can we add support for Adobe Lifecycle??
Re: BIRT support for PDF and Excel report Generation [message #892526 is a reply to message #892160] Thu, 28 June 2012 10:25 Go to previous messageGo to next message
For PDF BIRT uses iText, the xls emitter uses internal code. There are
other xls emitters in the community that use POI.
Jason
Re: BIRT support for PDF and Excel report Generation [message #892672 is a reply to message #892526] Fri, 29 June 2012 02:35 Go to previous messageGo to next message
Thanks for this helpful information. I also want to know if we can add support for Adobe Livecycle or any other open source for pdf or excel generation?
Re: BIRT support for PDF and Excel report Generation [message #892802 is a reply to message #892672] Fri, 29 June 2012 14:16 Go to previous messageGo to next message
BIRT has extension points for just about everything :> The emitter
extension points allow a developer to add an emitter that they code to a
running system. Dev Share on birt-exchange.org has some examples of
people implementing their own emitters. In addition you may want to
have a look at the tribix emitters on source forge.
Jason
> generation?
Re: BIRT support for PDF and Excel report Generation [message #893231 is a reply to message #892802] Tue, 03 July 2012 05:57 Go to previous message
ok. Thank you, this is really helpful.
Previous Topic:White space where rows are empty
Next Topic:JDBC Driver problem for MSSQL- Schema not showing up in Data Source
Current Time: Sun Jul 20 16:34:17 EDT 2025
Powered by FUDForum. Page generated in 0.03946 seconds
